who sells just the retaining clips for master links?
I bent the master link retaining clip on the new DID 520v o-ring chain I installed on my DR350SE last weekend. Seems I didn't have the sideplate pressed far enough in for the clip to go into the groove, and I bent it. It seems local shops don't sell retaining clips, just complete master links.
I ordered one of these along with a new masterlink:
http://www.rockymountainatvmc.com/pr...dFamilyId=3002
question #1:
Unless I can buy just the clips, I will have to buy a masterlink complete and toss most of the kit. Does anyone know where to buy just the clips?
question #2:
Can I peen the ends of the pins to retain the sideplate, rather than use the clip for which this masterlink was designed? Or does the clip-type masterlink only work with the retaining clip? I don't want to do anything that could cause the chain to come apartwhile riding.
Never seen just a clip. For the $3 for a complete master link, just buy a new one.
If you want to "peen" the link to retain, buy a rivet style link and use the proper tool. If you don't have the tool, pick up a clip style and call it good.
I wouldn't compromise with a shade tree mechanic attempt at retaining the link of the chain. Just sayin'.
^Yeah you can get the whole master link for just a few bucks....I keep a few spare ones in my tool box....
With a o-ring chain that is wider than stock the master link ends up getting
worn before the chain is used up. I replace the master link when I see it is worn. Just cheap insurance! :cheers:
Well the master link, like the chain is brand new. I just buggered the clip installing it.
In Canuckistan, a master link goes for between $9-$15, and the clip is a $0.10 bit to produce, that unfortunately, as far as I can tell, is not sold by itself.
Only 1 store out of 4 had the link I need in stock. So at $15+ 13% tax = $17, would you want to buy a new link?
Fortunately, a nice guy in the 4th shop I spoke with gave me a link from his odds and sods bin.
I have a Rocky Mtn ATV tool and a spare link on the way for $14, but this clip will get the chain sorted in the meantime.
