Brake Lever for KLX 110
The front brake lever on the KLX 110 is large by adult standards. I'm trying to find an aftermarket handle that would be a better fit for child's hand. Any suggestions?
See if one will fit from a KX65. They share a lot of parts.
We got some generic ASV branded brake lever off ebay for a KX100. IMHO, it's super small, however, it may work for you. IIRC, $40 for both brake and clutch.
We rotated the brake lever up, which helped. I then took a small bolt and put a small slit in it and slipped the bolt over the brake cable, so that it sits between the lever and bracket. That brought the lever much closer to the bar. I think I'm good to go. Thanks for the suggetions.
