Trailblazer 250 Piston Melt - Too Lean? Jet Size?
I have a 2005 Trailblazer 250 that I purchased last year.
Configuration at time of purchase:
0.020 Namura cast piston
high stall clutch
hot seat exhaust
oil injection disconnected (running 32:1 pre-mix)
.140 main jet (installed by repair shop to correct "low bottom end power" complaint)
Drove for one season. At end of season, after a 2 hour ride, my son rode it hard for about 15 minutes at which time it stalled and wouldn't restart. Teardown inspection showed a melted piston. I've since bored it to .040 over and installed a new Wieseco forged piston. Crankcase air pressure leak tests were negative. I can't seem to find any information on what the factory jet size is. However, the previous owner did give me the jet that was in the carb prior to replacement (.150). Prior to and after repair, When cruising 20-25 MPH, slightly opening (tip-in) the throttle results in what sounds like pre-ignition (spark knock).
I relly hope to avoid rebuilding the top end again, so any answers to the following questions and/or other suggestions would be greatly appreciated:
Is the .150 (OE?) jet large enough for this configuration?
Should I install larger jet and/or raise the main jet needle?
Type . . . . . . . . . . . . . . . . VM30SS Mikuni
Main Jet . . . . . . . . . . . . 130
Pilot Jet . . . . . . . . . . . . . 40
Jet Needle . . . . . . . . . . . 5DP7-3
Needle Jet . . . . . . . . . . . 0-4(169)
Cutaway . . . . . . . . . . . . 2.0
Air Screw . . . . . . . . . . . 1 Turn
Valve Seat . . . . . . . . . . . 2.5
Float Height . . . . . . . . . Parallel to gasket
. . . . . . . . . . . . . . . . . . . . . surface 1mm
Fuel Octane (R+M/2) . 87 Non-Oxygenated or
89 Oxygenated
At .40 over I would move to a 150 main and a 45 pilot. The pilot is too small which is probably your problem with the off idle stumble. :thumbsup:
Thanks Danco! I have a 150 main jet in there now. I'll verify the pilot size (is that jet marked - will I be able to tell)?
Is there any thing else I should check and/or verify to prevent another piston melt down?
Thanks again! :thumbsup:
  • Similar Content
    • By Question_Man
      Hey guys im between a split decision about getting a quad or a dirtbike. So I was just wondering what your opinions are and dont give me 'it depends on who you are' crap. This is a opinion question just tell me what you really feel and why. And if you can tell me the funfactors of your choice and why you choose whatever it was you did.
    • By entrpner71
      Well the 350L was short lived:smirk: and switched to the Scrambler so I figured I would let that die (quad was sold shortly after the thread was created anyway:thumbsup:) and bring up my new direction. A gentlemen is selling a 06 Polaris Scrambler on Craigs for 3000 and I could probably talk him down a little more. Trade in on KBB is 2810 so it seems like a good deal, he also claims excellent condition.
      The "criteria" is it would be for my mom (and grandfather on occasion). She wants something completely automatic with good suspension, strong power, and just fun. I want the 4x4 because she is not going to gun it when things get technical so this would pretty much guarantee her not to get stuck. It would be good also to pull out other bikes/quads and do some basic ranch work around their property (mostly hauling horse poop) too. I also like that my bother or my self could jump on and keep up with trx250Rs we just bought.
      So the question is this a suitable quad and how is the reliability of these atvs. I have heard they are a lot of fun and I don't think I need to worry about it being to much for my mom, she is not going to test it as long as it is predictable. Any experience or knowledge would be appreciated. This particular one is a 2006 but would like to learn about all model years as far back as late 90's. My other interest is when the AWD engaged automatically, that is a great feature and if she ever used it is just that much more confidence for her. thanks guys:worthy:
      P.S. other models/years and even makes would be consider if suggested. I am hoping to buy american but it is not crucial (buying used anyway). At 3K I would have a very difficult time talking my parents into it so if I could save money without much sacrifice by an earlier year smaller engine and so on please let me know.
      Last question (promise:p) how are these things on gas, not riding hard but light to moderate riding? We almost bought a banshee but the thing would eat 5 gallons of gas in only a few hours of hard rinding:eek:
    • By entrpner71
      So they both have really good life insurance policies and...
      I am wondering what a good quad would be for my grandfather 87 and mom 53. She does not want to spend more then a grand maybe 1200 to 1300 but that is max.
      I need something with
      A) RELIABLE!!!!!
      fully automatic trans
      C) at least 250cc, I don't want them to have to wring it's neck in tuff uphill terrain
      D) something cheep to maintain like a 2T with CVT belt driven, don't want to worry about gears and all the other problems
      E) 4X4, I don't want them to worry about getting stuck anywhere. They are not going to know to keep their speed up or accelerate to get out of ruts steep rocky inclines and so on.
      F) can't eat gas, must be somewhat effective on MPG
      G) it can't throw them off, it needs good constant torque and horse power but must be very predictable if it rears up it will loose them.
      H) something that can really take a beating. It will see a lot of hard work, towing horse poop, knocking down weeds, rocks just about everything. It is going to be tested:devil:
      I) forgot to mention this in the general thread I posted but must have smooth suspension, not pro caliber or caddy style but I don't want them getting beat to death by the seat:smirk:
      My grandfather is coming off my dads (ridden twice) TRX200sx but it lacks the power to keep driving easy and he has to shift, no clutch but I don't want my mom or him to have to deal with anything but throttle and brakes. After watching my brother father and myself ride my dad decided to buy another '86 TRX 250R and now they both would really like to try it but need something that inspires confidence not something that peels your head back over your shoulder:smirk:.
      I was thinking a 1991 Polaris TrailBoss 350L. It is 4x4, 2T so cheep to rebuild, low hi reverse band driven, green stickered and 4x4.
      So would this be a good choice or should I look into something els. I also want something with really good pulling power to take out brush and small trees, cutting trails and more important pulling people out of the mud or ruts when the get stuck. This is secondary issue but a big reason for wanting the 4x4 and larger displacement.
      Any help would be much appreciated, again reliability is a key issue. Obviously I would like plush suspension and lights and so on but buying something this old, I need it to work or any feature is useless, we can't throw large amounts of money into this quad right after buying it.
      Thanks to all:worthy:
    • By IHScoutII
      Can anyone tell me the good and bad about the predator? I found a 2003 troy lee addition for $1500, I haven't seen it yet but the guy said his brother ran it out of oil so he had a shop rebuild the engine about a year ago. He said they replaced just about everything except the crank which seemed like an important component to skip. Anyways, if there is anything I should look out for, let me know!
    • By mickeydee
      has anyone else had this problem?ive put in a new float valve and its still getting fuel in the oil and running rough.i checked the vacume pump but it seems to be working alright but im wondering if fuel is somehow getting sucked in through the vac hose from the pump to the intake.
