Linkage performance for 2010
Does any one know or can they find out if the linkage from a 2007 kxf450 is different than the 2010 kxf250.... and whether there would be a positive result from putting the linkage from the 2007 kxf 450 on to the 2010 kxf 250 ???? Thanks
the 07 kx450f linkage worked for the 2006-2008 kx250fs how ever there was revisions to the linkage in 09-11 so I'm doubting it will work..
Is there any way we can find out??? As someone from one of the big suspension companies gave me this information.
I have a 2007 450f linkage on my 07 and I have a 2011 kx250f that are in the process of being tore apart for regrease I will compare the two linkages in a few days and give measurements..
Thank you, thank you!!!!!
The 2010 250f and 2011 250f have the same linkage arm.
on a side note just read the motocrossaction pc suspension revalve review for the 2011 and they say the pc link arm is 1.5mm longer..and gives results... Lets see if this matches with the 07 450 link arm!! :cheers:
i put that linkage on my 09 from my 07 and it didnt work good. 09 and up stock works best save your money
Do you know the difference in length between the two??
If we could create a database of linkage arm lengths for kxf's this would allow all of us the possibility to fine tune our bikes!! Anyone have the motivation?? If you do the measurements I will make a table for us all to use....:cheers:
NO I GOT RID OF IT. also if your going with a link i would recomend 22mm clamps. the pc team runs both they kind of work together . plus the2010 has been updated since 07 i feel its not needed my 2010 is fine without a link, but im in the procces of putting 20mm clamps on. thats what you should do first then the link second if you feel you need it.
Already have the 22mm clamps :cheers:..... Going for the next improvement....as per motocross action 1.5mm longer link = big improvement.... just trying to figure out if this is obtainable as a stock link for 70$ instead of 250$ + import tax and shipping since I am currently living in Greece
Well, I havent taken the link off my 07 yet but compared it to my 2011 link and it looks to be identical in length.. I'm asuming the newer kx450fs have an even longer link so thats were mxa is saying.. I will confirm probably tonight when I tear the 07 down further.. I will mic both of them.
Nice, nice, at least we will have a starting point! I read that the 2009 kx450f has a longer link than previous models. Seems that MXA are still putting PC links even on the 2011 bikes.
I really like MXA, but every time Kawi changes their offset or linkage or damping to what MXA wished for, they always want more or something completely else. Or cry about the castle nut on the rear axle.
