will crf 450 SM wheels fit on a xr?
i have a buddy that wants to sell me his supermoto wheels off his 03 crf 450. my plan is to buy a xr 650 and make it a sweet street cruiser. will the wheels and brake re-locaters fit? if not what do i need to make this work?? thanks in advance
Generally, you can swap most wheels from bike to bike with a bearing, spacer and bracket adapter change. If you have a lathe or mill, know some who does or pay to have it done then it's pretty easy.
So do I need to get a different brake adapter? Where's a good place to get supermoto parts? This is all new to me
Go to supermotojunkie.com and ask that question. I was just giving you possibilities not definites.
Not do-able.
Not do-able.
Yes, it's completely possible with a bearing change.
I figured I would ask on here so I don't get flamed on smjunkie
Seen a number of guys try and not get it done. Caliper/rotor alignment problems.
I have 450r forks and MM caliper on a xr wheel set with rotor. I don't see why there would be any oddities with a xr fork and caliper setup on a crf wheel set.
...done it with an xr400 front, motomaster 320mm relocater (for xr forks),different wheel bearings plus spacers and found a smaller moose (mud) rear brake rotor ,or take an cr rear rotor and machine to xr400's radius
guess those guys got stuck too easily. :thumbsup:
So you can make CR wheels work with XR forks AND XR wheels with CR forks??
Sure could have saved me some wheel buying!
lol...the only rear rotor i could find
and the chain ran on a tiny angle :thumbsup:
Edited by josmo
add
I got crf rims in my XR650R :smirk: it was an easy job to do
Front rim is 3,5'' with a 120/70/17 pirelli supercorsa tire and rear is 5'' with a 160/60/17 maxis supermaxx tire.
I got it with the crf front brake 320mm adapter and its a straight fit on a xrr fork.
Only changed the bearings and used cr spacers to go with the original axles, all got lined up like it shut be.
Edited by rikco
nice job!:smirk:
Now that's sweet!
chain rub with the 5" rear?
If you space the setup right on a 650r you'll get 0 to minimal rub with a 5" rear
no chain rub on my rear tire but when you dont keep the chain in good shape it will touch it a little bit.
it's all verry close with the 5'' rim and 160/60 tire.
on the first picture i had a continental road attack (also 160/60) tire and that tire got more chain rub then the maxxis tire.
the white chainslider needs to be modified a little or it will touch the rim. :ride:
Edited by rikco
added a picture
