Very strange!!!!!!!!!!!!
Hi all,Well been out on the bike today after a costly rebuild and was great:ride:.I reset all valve gaps to speck.But after just on day there tight again:banghead:Im down to a 1.47 r intake,1.77 l intake,1.97 l exhaust,2.02 r exhaust.The valves were taken out to have stem sills fitted and a gen decote.I ran the fresh motor letting it warm up and cool down on the stand first couple of runs,then checked the gaps and all was good.Run the bike in at the track runs great and started first kick hot or cold all day.Get home clean and a general check over bike and the intakes are tight:banghead:Naw i ride pretty hard but im no bubba.Any idears guys.Is it just time to change the buggers?cheers lee
When you say valves were taken out to fit new seals and decote, did you replace them??? The stock intakes are titanium with a hard coating. Once they start to move, they don't stop. If they were not moving before the rebuild, your mechanic didn't lap them did he? The Ti valves can't be lapped, even a little bit.
What was the reason for the rebuild and what all did you have done????
Main bearings and conrod thrust washers went and destroyed oil pump and both cases,piston.Before the motor went out for its rebuild the left intake went to zero and right was .002".As i stripped the motor partly down and out the bike to save money,i saw the valve faces and the crap on them and said to decoke them.He said he took valves out cleaned and also new stem seals were fitted.He did say in past chats that they are titanium intake valves.So must no not to lap them in.When they are worn do they really go south that fast?Think the shims needed to give the correct gap are to small and asking the valves to fail.Dont no if im over thinking this or im on the right track.Thoughts pls lads
Nope, intake valves are toast if they zero'd before the rebuild. It's not the seals that make them go south, its that you have worn the hardened coating off of the Ti valves. Pull the head back off and get it done. AT MINIMUM new intake valves. Have your machinist clean up the seats and you CAN go back with new OEM valves. I would recommend replacing them with SS valves, as they will last much longer. Changing to SS valves requires new springs on the intake side. Several companies offer the intake kits for the 250s.
If you go with SS they can be lapped. If you replace with Ti valves, NO LAPPING AT ALL!!!!
What sort of time you guys getting on ti valves?I do like the way ti valves almost tell you there on there way out with all the shiming,As with ss i read they just snap.But what sort of time would i get out of ss.Im forever pottering about with bike and keeping it in tip top nick.:thumbsup:
Hard to say. Depends a lot on how you ride and how careful you are about dirt getting through the filter. A guy that putters around on trails and cleans the filter a bunch may get hundreds of hours. A teenager who bounces the rev limiter on every shift might get 20 hours.
I think the general consensus on the Ti is 75-125 hours, when well maintained. The SS properly set up seem to go about double that (or more). I have never heard of a SS valve snapping. Not saying that they don't, but I have never seen it. If you keep shimming any valve as the face dishes, it will eventually get thin enough the the edge will chip. That chip floating around can do some damage.
Some of my fav tracks i ride im only in 2nd/3rd gear,and end up on the rpm limit as theres just not enough time or track to change into next gear.So prob hard on the motor.Filter is always clean and oiled.I have bought crf r rear numberboard plastics though,so the left airbox opening side of the box dont seal perfect so some dust is getting in there as had to cut to fit.Do you think my intake shim sizes at top of page are to small for one more shim?cheers all
Hi Speedy :thumbsup:
You can shim the intakes all the way down to 1.20, we have a 450R with a 120 shim fitted, it starts 1st kick every time and the next time it closes up we'll need to have the seats re-cut and will probably instal SS inlet valves instead of Titanium.
Ian :thumbsup:
  • Similar Content
    • By Hayden Ploeger
      So I have never actually posted on one if these forums. I usually just stalk them to get answers but I messed up and I might be out 800 bucks🙃
      I have a 2013 CRF250L that I recently bought and I wanted to get supermoto wheels for it. I got online and almost ordered a set of warp 9 wheels but then I saw an add on Craigslist. Long story short I purchased lightly used warp9 wheels from a 2012 CRF250X not realizing the axles are different sizes. The rims are the same size as what comes in the kit from warp 9 but the spacers and bearings are larger on the wheels that I got. Does anyone know if I can buy new bearing and spacer kits to go in these hubs to fit them on my bike or will I need to purchase new hubs entirely?
      I work on a fishing boat and I'm off the coast of Oregon for a few weeks and wanted to order something so I can get these wheels on my bike when I get home.
      Thanks,
      The guy who f***** up
    • By yrun
      I have a new 16 crf250x.  Would like gear it up a bit for two track, orv trails.  How much can i drop the rear sprocket size without shortening the chain.
      Thanks men!
      Joe
    • By yrun
      I was working on installing new needle for JD jet kit today. While trying to get a bit more rotation on the carb i broke a little plastic tee on the top of carb (left side). I think its some sort of vent? Not sure if the brass part is threaded into carb or not? At any rate it will have to be replaced. Wonder where i'd get this little item?
      Any ideas?
      Thanks joe
    • By ronbuell
      Ever been bored or really ticked off by not being able to reach your fuel screw for trailside adjustments?  Well, I decided to do something about it, and not spend a bunch of money to boot!
      Parts liste included:
      Short length of brass tube. Short piece of old, broken speedometer inner cable. Nut from the rejects bin.   I welded the nut to the speedometer cable inner and soldered the other end to the fuel screw using the brass tube as a connector.  I didn't need or fab up a holder for the end, but I wouldn't be too hard. My DIY flexible fuel mixture screw works great and the price is right! I highly recommend this mod.
      Cheap, but effective DIY fuel mixture screw
    • By Frana
      Hi everyone. I’m new here so I don’t really know what to do but let me explain what’s up, so I bought this 2008 CRF250X today and everything looked in tip top shape, but within a few minutes of riding the engine and radiator gets to hot to touch and then the bike dies at low RPM, then it is a hassle to get it started(i drained the battery trying) and once it fires it dies super easily again like by touching the trottle or just idling and I have to be super cautious on the throttle to grt it going. I don’t know if it is overheating or if there is another problem, if anyone could help me it would be very much appreciated.
