Throttle cable fcr41
Hey all. Does anyone use there standard E throttle cables on their fcr41 mx? I have mine installed and have fiddled around with them but they still feel a bit stiff and the throttle wont snap shut. The cables are in good nick and worked fine on the old 39.
Cheers
the E cables wont work on a fcr-mx.
Ok what do I need? Would a throttle tube an cables from a CRF or WR work??
Hmm thought so. Only prob is I wouldn't mind doing it cheaper cos the mrs is starting to catch on! Thought I could go to the wreckers and pick something up until I can get a ssw one. And it would suck having to wait for a new part from the US seeing as it's finally ready to fire up!
Friend who has a 'E model installed a FcrMX-41 and he used the stock 'E cables .
i used e model cables with the 41fcrmx but there too short.i had to put both adjustment nuts on the inside of the bracket on the carb.even then it only just works
Yes, i still do! :thumbsup:
I think the pull cable needs the 2 nuts inside the bracket, the other is ok.
Thanks for the tip. Will be tryin it when I get home tonight! If it works it's break in time! At last.
Sweet it worked! Next prob shithouse battery won't turn it over :thumbsup: I knew it would happen tho. Oh well off to batteryworld tomorrow.
Wi I fry the wiring if I try to jump it from a car?
I jump it from a xt225 Serow couple months ago when my battery was almost dead , it started right away with no problems .
Before upgrading to the super start kit, "stock battery" I always jumped the bike of a vehicle:banghead:, new 190cc battery never any problems :thumbsup:
And its still cold here normal riding temp 5°C
Personally don't know why I replaced the stock battery when it was dying.
Super start kit worth every penny
