Trailer Floor Sealer
I am looking for an inexpensive, clear, gas resistant, non-slip flooring product to seal my trailer floor. I don’t want to add weight either. We sleep inside, so the goal is to make the trailer easy to clean (dirt and oil/gas). I have searched floor sealer on TT, here is a summary of what I have found:
ITEM – pro/con
~BEDLINERS – durable/hard to clean, stuck with it, can’t replace
~EPOXY – durable/cracks
~PORCH AND FLOOR PAINT– easy and cheap/shows wear and tire scuffs fast
~GARAGE PAINT - easy and cheap/shows wear and tire scuffs fast
~LINOLIUM – easy to install and redo/slippery, not oil or puncture resistant
~12” TILES – easy to clean, resists oils/heavy, costly
~RUBBER FLOOR MATT – easy to redo/heavy, odor
~RACEDECK – looks great/expensive.
Has anyone used polyurethane, deck sealer or a marine type wood finish for sealing their trailer floor so it is gas resistant and not slippery?
What have been your experiences?
Any other options that fit the bill?
I know I am being picky and may be asking for the impossible, but if a product exists, someone on TT will know. :thumbsup:
Thanks!
ITEM – pro/con
Thanks!
I can find pros and cons all everything,you will just have to weight them. I'd use a smoked gray color (brightens is up) rubberized coating thaty is gas an oil resistant, add a smidge of sand for grip. Not a lot of weight added this way.
