Is balancing SM tires needed?
The difference between ordering a set of tires online vs ordering from a shop is about $100 so my question is if it is needed to balance a set of tires if I try and mount them myself. I see the front wheel has 2 spoke weights and the rear has the regular weights so I assume it is necessary. Anyone mount their own tires on SM wheels?
Yes, they should be balanced unless you never exceed 40 mph.
Both wheels should have stick on weights, spoke weights are inaccurate, scatch spoke and can pop off.
You have the right tools to not damage the finish on the SM wheels when swapping tires??
Yep I do. Every one I know dose it them self. I fit my tyres to my sport bikes as well then take them to a shop to get them balanced. Cost £10 that's all. You dont really need to do it on a drz, I don't think.
you can try it yourself by literally balancing the wheel so there is not a heavy spot. If your not happy with the results you could go to a shop. I balanced my wheels and run up to 120 kms, does not seem to be an issue at ALL.
I mount and balance my own too. Even picked up some black stick-on weights a few years ago so they blend in with the black SM wheels. Google or youtube "static balancer". Really easy to balance on your own.
I've heard that static balancing is actually more accurate than dynamic balancing (what most shops use), but I have nothing to back up that claim, just what I've heard. Maybe others can confirm or deny.
WGW
Takes all of 2 minutes to balance a tire....if you are going to put in the sweat equity to swap it out, spend the extra moment to balance it correctly.
I picked up a motorcycle static wheel balancer at Harbor Freight with the standard 20% discount for less than $50. Well made, super accurate and easy to use.
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
