Need help with flywheel bolt!
2008 KX250f. Trying to switch out my cam chain and the flywheel bolt will NOT budge at all. Right now I am using a oil filter type wrench that I am wrapping around the flywheel so it won't move while I remove that bolt but it is on there really really tight. Any suggestions?
id try a strap wrench and an impact gun. Thats what i did on my 144 anyways , worked well . hope it helps
impact wrench! just make sure you got the wrench set to losen!
