YZ125 2001 questions
well guys the dream came true and i got a 125. amazingly fast. but ive had it for a few days and i dont know much about it and i have some questions.
1) will riding in midrange help foul my plug?
2) how can i tell when my plug is dying and when its fouled ( besides it wont crank)
3) should i run 50/50, water or pure antifreeze?
4)how do i raise the idol speed? my yz wont idol at all :thumbsup:
5)how often do i need to replace the rings and top end if im going to do NO racing, casual motocross track, harescrambling, and gncc stuff?
1. I have never had a issue with the plug fouling in a midrange
2. as you are riding when you give it throttle you will feel the engine bog even in first gear at low speeds
3. as far as 50/50 i know that full service manual says to use 50/50 but not sure about pure antifreeze
4. the idol speed screw should be right above were the fuel from the tank goes in. Loosen the lock nut, turn the throttle stop screw until the engine runs at the slowest possible speed then tighten the lock nut
5. some people change there piston and rings every 25 hours or so. but who has that kind of money. I think you can stretch it out a little longer then that since your not racing. if you stay off the rev limiter you should be fine for alot longer but to give a specific amount of hours i am not to sure. just judge it on how hard you ride it and how often you change the oil. hope this helps
So how can I tell when I need to replace rings. With the kind of riding I do is a top end a year ok? And rings twice a year? When I bought it the top end was two months old. Also, does a bad plug make it hard to start?
Yes, a bad plug makes it hard to start or it just won't start or stay running. If in doubt, get a new plug...don't mess around with trying to clean the old one it's not worth it. I don't want to get you confused and talk about too much yet but let's get you to a good baseline and go from there:
-Get a fresh plug
-Get some fresh gas and Yamalube 2TR premix and mix correctly at the ratio the previous owner said to (If no guidance, go with 36:1)
-Clean and oil your air filter
-Check your silencer's packing and replace if it's all caked up with gunk or if it's disintegrated
-Start your bike and run it. Did it start up ok? Does it run smooth through the range of throttle and sound good? Yes, then adjust your idle as stated above and have fun. No, then report back with your findings, ie: it's bogging; won't start; starts then dies; etc.
This is just a base but there are other, more complicated and common, things that may need to be done such as jetting, carb cleaning, top end, and so on. More information on that to follow if needed but it sounds like you may have just fouled a plug or forgot to check/clean something since you said it has been running good at some point since you bought it.
I still had questions about the top end and ring. When I got it there were 3 races on it. I checked it today and the compression is great. How often do two strokes go on top ends? And rings? I will not be raciNg motocross, just gncc stuff. I mix premix at a ratio of 32:1. Also, what would happen if I put some of that new antifreeze in (just a small amount) With what could be the old kind? The one in there was kinda yellow and the kind I added is greenish.
I don't think mixing the antifreeze will be a problem but why not just drain the old stuff and refill with new? As for the top end question, you are going to get a zillion opinions on how often to change it. Really, it's up to you. If you have good compression and she is running great than leave it be. If and when you notice lower compression, less power, hard to start...change it out. Or...pick an interval like every 30 hours and it will be cheap insurance for your motor.
32:1 is a good ratio and will help keep the motor running strong, just make sure you ride it like you stole it at the end of each riding session right before you hit the kill switch...that will help keep the motor/exhaust cleaned out which will help with reducing a fouled plug.
  • Similar Content
    • By doolan
      Hi guys I have a 2018 yz250 looking at changing springs front and rear I'm 200 pound ride b class moto.
      Having problems choosing spring weights using the calculators as mx tech say I need .45 fork springs and 5.2 rear but racetech say .48kg forks and 5.8kg rear.
      What are other bigger guys
    • By YamahaYz1
      Hey TT, I know there's endless topics on YZ250/ two stroke tuning in general but I have not been able to find one that helps me get my 09 YZ250 set up for my riding style and where I ride so I'm here asking for help. I got this bike around 1.5 years ago and have not known how to set it up properly. I know no one can give me a perfect set up but I'd like a good starting setup to work from and tweak to perfection. Throughout this time I've had this bike, its always been covering the bottom of the entire silencer and dripping all over the swing arm and rims with oil. Also, the joint between silencer and expansion pipe has oil around it too but I've heard I have to close the gap a little to squeeze the silencer a little tighter and stop the leakage there. I don't have too much experience messing with carbs but I've messed around with previous two strokes and tuned them a little better. I change the oil on my bike after 15-20 hours on it and clean and oil the air filter after almost every ride. The sparkplugs never last me more than a few months but recently have been lasting me no more than a few weeks. With the excess oil from the pipe and spark plug fouling you can see why I need to set my bike up to stop this.
      The bike:
      Completely stock with V-Force 3 Reeds and a FMF Shorty silencer.
      Usually running around 32:1 premix with 91 pump fuel because I prefer to keep it well lubricated instead of running rich.
      Riding:
      I ride enduro in Ontario, Canada. So mostly single track and some fire roads but nothing close to MX and not a lot of time wide open. Therefore, probably mostly 1/4-1/2 or 1/4-3/4 throttle range.
      Where I ride:
      Usually 0-500' above sea level. With temperatures ranging from around 15-35 degrees Celsius (55-95 Fahrenheit).
      If anyone can give me a setup to go from, that would be very much appreciated. Even multiple set ups for different temperature ranges or any suggestions would be much appreciated. Thanks and sorry for the long read, I just didn't want to leave anything out. Ask any questions if you have any, too.
    • By Goon Rides
      Hey guys... so I have a problem... I took the bike at Cal City, broke it in, and while I was doing so, the bike was bogging in first gear (Yes, first gear). Also it doesn't idle at all. I have to keep blipping it otherwise it'll stall. So I adjusted the screw circled in image 1. Well I was listening to the sound of the of the bike, yet the rpm's weren't increasing, and it was still stalling. So then, I unscrewed the screw in image 2, well I found out that it was fully twisted to the right. So then, I twisted it to the left, still nothing; it was still stalling... where's the idle screw? I am sure that the screw in image 1 is for the air/fuel mixture screw, and the screw in image 2 is the idle screw, just broken? I don't know, any and every help would be appreciated.
    • By Nolan Mitchell
      I’ve got this 85 yz 250 with a odd rev problem, it starts and runs fine, good compression but when you Give it wide open throttle in newtral the bike will rev to around 5.5 k rpm like platow for a bit there, once you’ve waited  a few seconds there for it to clear itself out until it reaches its max rev whatever it might be 7k rpm even happeneds when the bike is defenetly warmed up after a wide open pull. But it doesn’t bog at idle to 3k. The trotte response when riding seens normal. However i don’t feel that the motor is getting its full potential. Honestly I’m just confused on what’s goin on and i need some help
