For you "Dollar Stroke" guys!
Had my RMZ450 done by Pro1RacingHeads out of Phoenix (Tempe). Machines his own non-beryllium valve seats out of Mold Star 90 stock and valve guides from a nickle-bronze alloy. He doesn't cut the valve seat but uses a Haas machine to profile them. He does porting and verifies his work with a flow bench.
Haven't noticed much change on the bottom end but did not loose anything. Head starts to shine mid-range and above!
http://pro1racingheads.com/Pro1RacingHeads/Home.html
Edited by rmzpegger
Great videos, thanks.
Makes me think about how much fun it is to ride a 250F MXer, BUT as much as I enjoy 4 stroke power, if you wanted to put 70+ hrs on one per year, the economy of owning a 250F MX bike does seem a bit scary. Probably the best solution would be to have the nice 250F but put most your hours on a 450 or 250 2-stroke.
Some magazine journalists in aus writing about how the KTM350 or EXC is the perfect compromise size engine, but if those 350s are revvers, I'm not so sure about that. For average Joe Rider, I still think the 450F or 250 2 strokes are the perfect bikes.
  • Similar Content
    • By tanner_shany24
      Hey guys, I have a 2012 KX450f and it is giving me major issues. I will give you a run down of the history of it. I bought this bike a few months ago and have only ridden it really once, yes once! When I bought it everything seemed to check out, it ran fine, started fine, sounded fine, so I bought it. Took it out to ride and the first hill I hit it got really hot and overheated like a SOB and spewed coolant everywhere. I thought to my self maybe it was because we were riding trails slow before so maybe when I actually got on it it got too hot. After that though, it began to overheat every 3 minutes no  matter what, I would ride it for 3 minutes, and have to stop to let it cool down because I was scared I was going to melt the top end. Got home and started inspecting, found out that oil and coolant was mixing both where the oil is supposed to be and where the coolant is supposed to be. After some research I found that the 2012 450 had head gasket issues. Assuming that was the issue, I took the head off and got it resurfaced (it was actually decently warped) and put new gaskets in everything top end related. Piston and cylinder looked brand new by the way. So I put it back together, started it up, and it instantly started spewing coolant and oil mixed out of the crank case breather hose. Like literally as soon as i started it and it would make a puddle on the ground in 10-15 seconds. I'm at a loss here, brand new coolant and brand new oil, brand new head gasket and resurfaced head, and it instantly started doing the same thing again? What could it be? Is it worth my time or do I part the bike out? I have put way too much time into this bike to want to tear back into it again unless it is something cheap to fix, if not I am going to post it on craigslist and let someone else deal with it. Overall this whole experience makes me want to go back to a 250T! XD
    • By Sam Mclean
      Hi new to this site.
      Ive just bought a cheap kx450f with what i thought would be a minor issue.
      I was told it was only running with the choke on and i thought easy fix, just a blocked jet. So i pulled it apart as must of the person before me and i find a broken soround thing that the plastic case sits on around the pilot jet. So i appoxy that back on unblock the jets and clean it all out, put it back together and now i try starting it for the first time and see the fuel dripping as it was when i bought it. When i look closer i see it is seeping from what looks like a crack in the float bowl. Ahhh
      So my problem is. Looking for a cheap carby might solve all my problems or just a float bowl at worse case. Now i can find many kx450f being wrecked nearby so im wondering are most 450 carbys the same? Will one of a yz450f work?
      Can someone please help
    • By Sam Mclean
    • By BadcaseofTB
      I missed tracking where this little top hat came out of in my 2011 kx450f. Was thinking clutch or right side engine cover. Any help would be appreciated I can’t seem to find it in the manual.
