DRZ400s sprockets modify
just getting into riding some steeper single traks and find i'm bogging down enough to want to change the sprocket configuration....any suggestions? heard its best to use a drzE combination, others say going down to a 13 front would be good enough...is there a combination that would fit the chain i have now?thanks
Front sprockets are cheap, drop to a 13t. If you like it, loctite it and ride for a while. Don't over think it...make the cheap change and ride. IMO.
13/48 for single track, 15/48 for dual sporting, 15/44 morading around town. Have a 14 too but not much call for it between the 13 and 15.
14/41 here and it is plenty powerful enough for single track and still gets me up to 65 but it's a bit buzzy.
If you have the standard 112 link that comes on the S you can fit 14/47 no problem. I just put 14/49 on my S (I haven't had a chance to try it yet) and it just barely works with 112 links. Requires the adjusters to be all the way forward.
i ride tight ST...running a 13/52!
It depends how slow you need to go....Just keep in mind the lower you go for 1st, is going to bring your 5th gear cruising down along with it...
Maybe try 1 tooth lower on the CS and see how that works for you..
assuming you are starting with stock S gearing, going to E sprockets vs. keeping your current rear and dropping to 13 in the front will be about the same from a gearing standpoint.
stock S gearing is 15/44 for a gear ratio of 2.93
E gearing is 14/47 for a gear ratio of 3.36
S with a 13T front is 13/44 for a gear ratio of 3.38
the E sprockets might be a little easier on your chain, though. the smaller the sprocket gets the tighter the chain has to bend to get around it. i don't know if it really makes much difference, but, in theory at least, it could cause your chain to wear more quickly.
(i run my S at 14/44 which helps a bit relative to stock gearing on single track, but still lets me cruise at 70mph on the highway without problem. i would like to go 14/47 for off road, but am a bit hesitant about what it will do to me on the highway...and i end up riding a lot of highway. i'll probably try it out at some point, though.)
You can do a 14/47 sprocket set-up without changing the chain. I did and it gave me the grunt I was looking for without too much loss for the highway.
I went to a 14 front on my S about a month ago and didn't realize until a couple days ago that the rear is a 45. My commute is around 60-65 mph. The 15/45 put me right in the bad vibration zone at this speed. With the 14/45 the little raise in RPM makes 60-65 much smoother in the footpegs and handlebars.
I took a small step and went from 15 front to 14 and it made a big difference on my S thinking about teh 47 in back but happy for now.
