Dust into the Left Cranckcase
Well I think I have a big problem, Yesterday I washed the bike for routine maintenance when removing the lid of the left case I found dust.
It 'has given the seal??
What should I do?
Dust in there isn't an issue, oil is.
Blow it out with compressed air, and throw a new seal on there.
IMO, pull the stator and see if you can see any type of oil seapage from the seal. Frankly, the seals on these things are so cheap, you might replace it anyway. Eric Gorr told me that if you find dust in the stator area, there is a good chance you have a blown seal because the dust flies around and blows the seals.
Ok thank you =)
exaclly.
What should I do?
Your drive chain master link is on backwards. You might want to turn that thing around before you lose a chain. Closed end of the master link clip is supposed to point in the direction the chain goes.
the chain clip is on the correct direction.
Only if she is riding the motorcycle backwards. the closed end of the clip is supposed to be pointed in the direction that the drive chain flows. This bike has the open end pointed in the direction that the drive chain flows. It could catch on the chain guide and flip off.
NM, I was looking at the picture again and I was wrong, there is some dirt on the chain that fooled me. Upon closer inspection, the clip is on as I described above.
what are you talking about? im pretty sure its the right direction. i can clearly see the open side is at the direction to the rear wheel. zoom in on your browser
Sorry, I qualified my statement. I should have just deleted the post.
To keep this from happening I also put a little bit of Marine Grease over the rubber gasket. Almost like the same concept as what grease would do if you use it for your air filter lip. Traps dust before it gets into places it shouldn't be.
What should I do?
If you look at about the 2 o'clock position it looks like it has a breather area on the case. Some bikes have these at the lowest position to allow any condensation build up to drain out. A little dust is okay, but to much moisture is bad (Rust). If that is indeed a breather area, try running a chain guide/guard around the front sprocket. It may lessen the dust.
Chain clip is on correctly.
  • Similar Content
    • By D.Barrett
      Kicking around the idea of selling my CR250. I have other bikes and never get a chance to ride this one.
      This is a well-maintained bike with tons of aftermarket parts. It's set up primarily for woods/single-track riding, but will still do just fine on an MX track.
      Engine:
      -Fresh Pro-X top end(<1 hour)
      -FMF Gnarly pipe & FMF Shorty silencer(<1 hour on fresh packing)
      -PWK Air-Striker Carburetor(bought new from JD Jetting last year)
      -Steahy 10oz. Flywheel Weight
      -Boyesen Rad Valve with Carbon-fiber reeds
      -TwinAir air filter
      Misc:
      -Excel Pro-Series Wheels(19"/21")
      -Brand-new Shinko tires(546 Front, 505 Cheater Rear not mounted yet) w/ Heavy-duty tubes
      -Works Connection Radiator Guards
      -Skid Plate
      -FMF Factory 909 Handlebars
      -Polished Frame
      -Sunstar 13/51 Steel Sprockets(new in box)
      I'm sure I'm missing a few odds and ends. Comes with a Bill of Sale only. (708)287-1998 - Dave
    • By waldo
      Parting out 2000 cr 250r: frame 150.00, seat with brand new fx cover 30.00, sub frame 30.00, pro circuit works pipe 50.00, kick starter 10 bucks, tank with shrouds 30.00, rear shock 45.00, swing arm 40.00.  make offer on all other parts in picture. Buyer pays shipping from 36092 zip.
    • By BabyGroot69
      Hello,
      I could not seem to find a similar thread so if one exists I apologize. I have an 02 cr250r with an 01 motor. I need to buy a new silencer with a spark arrestor because the current one does not have one. I am not sure if the owner before me used an 01 or 02 silencer because I have read the frame had significant changes from 01 to 02. Any thoughts? Thanks!
    • By Christo6060
      I want to restore a 1996 cr80 that doesn’t have any graphics and absolutely love the 1994 cr125r tank shroud graphics, I can’t seem to find anything that fits the cr80 with those graphics. I found one last week but lost the page and couldn’t track it down again, do the cr125r graphics fit the cr80 tank shrouds? or does anyone know where someone could make them for cheap or know about any in Australia
    • By cerialsledder
      Hey guys,
      Could someone please explain the numbers on a needle jet for a mikuni carb?  I'm currently running a 38-73 needle but a lot of the people I talk to say I would be happier running a 38-70 needle.  I don't have a problem with going with what other recommend but I would like to understand the numbering for the needles first.  I understand the nozzle sizes, main jet and pilot jet it's just this damn needle thingamobob
      Thanks a lot
