Rmx power valve maintnece help
hey guys, i was just wondering if i need to clean out my power valves and if so how often?
I have read here that it should be done at least at every top end rebuild unless you suspect problems with it. If you have not had it apart in a while, you may want to do it just to make sure all parts are ok and that none of the screws have loosened up. When I recently did my top end, I removed the PV and one screw was very loose which could have caused some major damage if it got sucked into the cylinder.
Thanks, i’ll go have a look at it on the weekend!
