DRZ400SM stage 2 jet kit gone bad??
I put in my stage 2 dynojet kit the other night and everyone seemed to work fine, i replaced the needle on the 2nd ring down from the top and i replaced the main pilot to 155 and did 3x3 mod for extra air flow, but the only problem is my bike idols fine on no choke, but even in cold the bike will not start nor idle on choke, meaning running too rich?! what would i do to fix this, i followed the instructions on the jetkit paper and backed out the screw 3.5 turns, would i screw in the adjuster a half or full turn to stop this or should i install the pin on the 4th slot instead of 2? or niether, help if out please thanks
