DRZ400s Rear Compression Question
I have a 2005 DRZ400s, I am running a motard setup.
My issue is the Low Speed (small screw inside nut) compression adjustment - it simply spins endlessly in either direction with very little resistance.
There is no leaking and other than the fact that it is "stuck" at a setting that is too soft works fine. I am looking for Max Stiffness - if it has to be stuck at one setting.
Any ideas on how to fix / adjust?
the screw has been forced passed its internal stops and broken, the only repair is a new shock.
Check e-bay
E. marquez had a post about this exact topic recently, saying the only way to fix it is to get a new shock and replace the part.
But you might as well just use the new shock and not mess with the valve.
-Zach
Ouch - thanks
You can get a rear shock on ebay for fairly cheap.
