XR250R cam exhaust lobe wear
So my XR250R had lost compression. I puller the top end and the ring end gap & piston clearance were fine. I then decided to check cam lobe measurements. Both exhaust lobes were way worn down. They even had a visible wear to them when compared to the intake lobes. Do I need to replace the rockers too with the cam as the exhaust rockers are not as smooth as the intake rockers now.
Yes, replace the rockers as well if they show wear. The faces are hardened, once that surface is compromised they get consumed at a much quicker rate.
