06 trx 450R carb settings.
what info do i need to know as far as measurements go for my carb?
mixture screw turns and float levels ect.
i dont have a manual and i cleaned my carb last night, now the thing runs good but when in gear and you go from 0 throttle to Full Throttle the motor will basicly die, or bog itself to the point where it almost dies.
i have a feeling its all in the mixture screw, but also thinking something got into the main jet as i was putting it back together...
Thoughts?
atv is stock other than a slip on pipe. everything internal is stock. also dont think elevation has anything to do with it...from South Dakota.
