What should I get next?
I'm looking for ways to improve my 02' cr250r
speed,power,handling,etc
looking for suggestions on things to get for increaced power/performance.
so far i have:
factory connection suspension
fmf fatty pipe
fmf shorty silencer
airstriker carb
vforce reeds
any suggestions?
Is your suspension properly sprung? Is it valved for your style of riding?
I hear that the rad valve responds better than the v-force. You may want to try some motor mods, porting, and squish band clearance.
you could try advancing the timing. just take the fly wheel cover off, on a honda on the bottom stator blot there is a timing lock plate with a small in it. you can it off, loosen the other stator bolt and turn it alittle way clockwise alittle and it will give it a harder hit and alittle more throttle response. if you want to put it back at the stock setting just install the little plat on the bottom bolt and it will set it at stock setting.
so far i have:
fmf fatty pipe
fmf shorty silencer
airstriker carb
vforce reeds
any suggestions?
What type of riding do you do? Im sure that you know this but the way you "improve" a bike has a lot of variables. The ways that I improved my 91 CR500 for single track would suck on my 01 CR500 used for dunes. Same bike... but very different mods to improve them. Also, how much are you looking to spend and what are goals? i.e. HP > reliability or vise versa? Since you have a fatty and an airstriker, I am assuming low end is important to you also?
yes, i mosty do track/trail riding.
and i think reliability is more important to me
try some differant sprocket sizes and maybe a new main jet, then again you could also bore out your cylinder and get new pistin and rings for some more compression little more performance
