Lookin for some advice on mods and tech tips
Hi, new to thumper talk and I was just lookin to get some advice about mods and tech tips. So I just picked up a new 09 drz-400s and was wondering how I can get a little more snap out of it by making some minor tweaks (preferably the ones that cost little to nothing) Ive heard I can make some of these tweaks to the exhaust and air box but im not sure what. If there is anything else please feel free to state them. Its coming up to its first oil change so I was also wondering if fully synthetic oil was a good choice to run in this bike, and if so what brand and what oil filter would I use. My last question is about valve adjustment, roughly how many K would I need to make adjustments and how would I go about doing this. Thankyou in advance for the advice.
Hi, new to thumper talk and I was just lookin to get some advice about mods and tech tips. So I just picked up a new 09 drz-400s and was wondering how I can get a little more snap out of it by making some minor tweaks (preferably the ones that cost little to nothing) Ive heard I can make some of these tweaks to the exhaust and air box but im not sure what. If there is anything else please feel free to state them..
Welcome to the TT party....:thumbsup:
It all depends what you call cheap???
From lowest to highest $....
Locktite fix the counter shaft sprocket, counter balancer nut, primary nut, stator screws, flywheel/starter gear fasteners.
Remove the rear suspension and swing arm, clean and grease the bearings.
Remove the steering stem , clean and grease bearings.
Do the free power mod.
Install a Manual cam chain tensioner.
Install Case Savers
JD Jet kit for the stock BSR36 carb and the 3x3 air box mod.
Install SS brake lines front and rear.
Re Spring and valve suspension to suit your riding.
Install MRD SSW exhaust
When you can afford it, go for 94mm Big Bore kit ,4mm stroker crank , big valves, RHC stage 2 valve spring kit , Head Flowing, RHC 187 cams, FCRMX41mm Conversion kit. ,SSW Super Start kit...
Full synthetic..:thumbsup:...I use Hi Flow Filtro..OEM is good...http://www.thumpertalk.com/forum/showthread.php?t=665513
I do mine every 5,000kms(3K Miles).....
http://www.thumpertalk.com/forum/showthread.php?t=813179
craigo nailed it, you can find treads about every thing he said in FAQ on the drz form it self.
After all your locktite fixes and you have greased your bike.
Stock DRZS hp 33-35hp.
Best bang for your buck hp wise,+4 big bore, 12.1:1 and up on compression, FCR39mx, 3x3, SSW/MRD and I guess hot cams or E cams. Plus the MCCT
Hp around 45-48 with said up. those parts costing around 1,500
Someone correct me if you i'm wrong.
welcome to TT and really hope you enjoy Your new toy
good luck
do the 3X3 mod to the air box and cut out the restrictor on the exhaust tip and rejet the carb. the whole thing will cost you about $75 for a jet kit and you WILL notice a difference.
Sweet man 75 bucks sounds like a good price for a little extra power.
Would I notice a difference say if I were to just replace the stock exhaust with an after market system, and if so would I need to change anything down the line?
Craigo had mentioned that Hi Flo Filtro oil was the top shelf oil to use, so I was wondering if anyone has a link to a website where I could purchase it, along with a synthetic oil filter?
Yes, installing an aftermarket exhaust does make a difference... I recently installed a yosh TRC (same as a MRD/SSW) and did 3x3 and JD kit and it completely transformed the bike. I would recommend doing at least a rejet. 110% worth it
i have a friend who is very mechanical (knows what he is talking about) although you might think different in just a second... i mentioned to him giving me a hand jetting my bike (when i get it lol) he asked if i planned on an after market exhaust or anything... said it wouldnt really be worth it if it couldnt really "breathe" is that the point for cutting out the restrictor in the stock pipe? and how is that done? i want to get an ssw down the road but obviously you all know the price of those! its not going to affect anything such as excess wear and tear or anything if i jet iiit waaaaay before i put an exhaust on it? (and yes with jetting i plan on doing the 3x3 as well)
Of course you can do anything you want to the stock exhaust system but as said before on the S model modifying the exhaust only makes it louder without power gain. The small diameter head pipe is the main restriction and anything you do without going to a bigger diameter head pipe (aftermarket full system) doesn't gain anything power wise.
ok good point... so on an sm model will 3x3 and jetting give me any performance differences if i still have the restricting header pipe? or should i just wait on the jetting and do it whenever i can afford the exhaust?
cool deal thats what i was wanting to hear! although its probably ill advised to do mods like that if the bike is still under warranty huh?
I'd look for a way to be able to do it anyway. If it's a non-silly dealer, the 3x3+rejet won't void. Many dealers are silly though maybe, IDK :)
Generally if you have a warranty claim that's not related to your re jetting etc you should be fine..
But say your engine seized due to extreme lean jetting ,you wouldn't be covered with warranty..
As soon as you open up your engine( i.e.BB kit, cams etc) and had an engine failure, . you could pretty much kiss your warranty goodbye..
As mentioned , just run any potential mods past your dealer to cover your arse....
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
