Help needed bikes running odd.
I have a 2006 crf just had new valves piston gas flowed head and stage 1 hot cam but its not running right, when i off the gas it pops and bangs till you get back on the gas and it dont feel to have the power it should. i dont know what jets the bike has.
lean condition, the causes could be
1. lean jetting
2.exhaust leak
3. hot start stuck open
Definitely very lean!!
If you have had the head and cams done, you will most definitely need to re-jet the bike to get more fuel in, to balance out the amount of extra air that you have now got moving thru.
Do a search in this forum - I'll be willing to bet your jetting solution is posted on a thread here!!
Porting and cams require a leaner mix, not richer.
Decel pops are caused by:
Exhaust leaks/no packing
Hot start stuck open
Clogged pilot jet
Keep in mind too, you are running a race engine for an MX bike, not a trail bike. Race bikes do not coast. They are all WOT then 100% brakes. If you are coasting, then you are not a winning racer.
Jetting and timing?
