Detailed footpeg bracket pics
Im gonna build a set of those lowering footpeg brackets out of aluminum and see how I like them. I can get pretty much any aluminum I want from work for free, and basically do most of the work there too.
Ive got a few days off for riding and fishing in a few weeks. Trying to get my bike set up to make the most out of the few precious days Ill have off.
I dont wanna drop the money on the procycle ones, if im not sure Im gonna like them. These'll just be temp if I like them being lowered, as I dont want to keep the brackets hanging down under the skidplate.
Ive seen the detail cad style drawings of them. I cant seem to find one now. If someone could post one up, id appreciate it.
Thanks
Thanks a bunch! Looks like that's your drawing then. Did you build a set? I'm sure I can figure it out from the other measurements, but you know offhand the height and width measurements?
Thanks again!
Sorry Nordie, what i meant is can you create a CAD file and a .dxf file for a specific project? This is a bit off topic for this thread, but i have this large chunk of 19mm 6061 T6 aluminum and i wish to fashion a custom fork brace. In fact i have enough of the material to make several of them. I can either whittle it out on a mill at work, or with a .dxf file on a CD i can take the material and the file to a water jet place here in town and have it/them cut out with an NC water jet machine thereby reducing the amount of cutting i would need to do on the mill. I have Qcad on my Linux machine here at home, however i have yet to figure out just how to get everything correct with it and would prefer to let someone proficient in CAD do it. I could even mail one to you there in NZ, for your efforts, if you are still running the stock front fork.
I can give it a go for sure.
I'm using QCAD on Linux too.
Usually I'd lay it out in QCAD then import it into VariCAD and extrude it into 3D to make it look cool.
