2000 CR 250 R Help Please
Hi I just bought a 2000 cr 250 and it needs a new top end. when i took it apart, it had a pretty good scratch down the inside cylinder wall. I was wondering if i should resleeve it or bore it out and replate it. thanks
cr250rrider199
Get it re-platted. It's not expensive, fast turn around, and you never know what you'll get on E Bay. The cylinder may look good, but could be out of round causing more headache and more lost money.
exactly how big is this scratch and where is it located, you might be able to just salvage the cylinder in its current condition, especially if its a small scratch and its located below where you actually need to hold compression.
how deep is it? if you can't feel it you might be able to get away with a hone. If you can feel it send it to Powerseal. Much cheaper than buying a new cylinder. If you want it bored, send it to someone that specializes in boring such as Eric Gorr. There's much more to boring than simply making the cylinder bigger.
I would send it to Powerseal or another company that replates. For around 200 bucks you'll have a new cylinder.
Before spending any $ you should ask somebody who knows cylinders. I've thought the same thing before and my local Honda mechanic said that he'd put a piston and ring in it and ride it just the way it is (and he's the one that would've made the $).
