bike to low
I just bought a wr250f,the person I bought it from must have lowered it.Not sure how to make it taller.It looks like the connecting rod is stock,could it be the swing arm rocker.
Mine was lowred to as it was owned by a female, it looks all standard, would like to know how to raise it.
Is the spring and sag set right? When I got mine it looked like a low rider and the forks were way up in the triple clamp and the spring was adjusted way low so I cranked it up and set the sag
Is the sag set to 100mm? Are you much heavier than the previous owner and need a heavier spring rate? Is the rear shock blown?
