2010 and 2011 sprocket interchangeable?
Looking at getting the primary drive sprocket and chain combo from rockymountianatvmc.com but it doesnt list the 2011 Kx250f, only up to the 2010. I figure that they're the same but I just wanted to check. Also what is the chain length needed?
Sorry for the newb question :thumbsup:
Ok, yeah, I was wrong, you don't need a 120 link chain. The stock chain is only 114 links, so I guess I would just see how far the wheel is forward and you can judge whether or not a 112 link will work or not. Don't forget to compensate for if you are getting a rear sprocket with more teeth.
yes it will interchange.. I highly suggest staying with the 50t or maybe a 51.. I tried a 49 and it sucked.
Ok a 112 should work then since I'm going down to a 48 tooth from a 50. Thanks for the help.
Edit:
So a 48 would really be bad then huh? Hmm they don't give me an option to change the sprocket out, guess I'll have to look elsewhere. Thanks for the heads up.
I ride trails and mx so a 48 wouldn't help me at all it seems. I was going to just try it but it sounds like a waste.
