06 CR250, Gear oil questions
OK, So I have this 06 CR 250, Ive been changing my gear oil after every ride and Ive come to notice that its not clear. It goes in golden and even after 1 heat cycle it comes out dark. Im using castrol 10-40 motorcycle oil. Im not sure if its the oil itself or if there is something else is wrong. Also the bike is like half fouling plugs. It will run perfect then if I'm not on the throttle wide open even for a very short period like less then 2 mins it runs perfect for the first 1/3 of the throttle but very rough for the rest of it. It can be cleared out but takes awhile and its not constant so I kinda don't know when its going to happen. Im running Klots super technoplate at 40:1 with shell 93 and have run it in the past on this bike with zero probs.
Any oil you run will come out dark/black/grey after one ride. And as far as loading up sounds like a little bit rick on the pilot, maybe drop the needle a clip and see where that puts ya. What do your plugs look like?
For starters, your gear oil will have no effect on what goes on in your engine since the transmission is in a separate compartment. Unless you have a bad right hand crank seal. Second, the oil in the gear box gets dirty quick because of the clutch. It definitely sounds like your jetting is a bit rich on the needle and possibly the main. Keep an eye on the plug with each change you make.
The rapid color change in crankcase oil is normal on the '05-'07, and it's predominantly due to the ALUMINUM clutch plates. CHange the alum clutch plates to steel plates, and you'll see a 50% reduction in contaminated oil. However, going from alum to steel, you should see a slower revving engine, but in all honesty, only a pro racer is going to feel such a minute variance.
i dont get people who change there oil every ride. the oil isnt even near broken down. wast of money and time. now every 5 hrs i can see. so give or take 3-4 rides(for me)
i do it every time, 5 hrs on the dot and never had 1 problem, even after 5 hrs to oil is still in perect condition. contaminated from clutch particals? yes, always. but still has all its lubrication qualities.
The condition your describing could be a little jetting and fuel mixture. from factory they were jetted for 32:1 , 40:1 is leaner in oil, but richer in air/fuel!
Make sure your powervalve cables are ajusted properly and it does have the correct plug the 05-07 cr250's run a br9eg-n-8. I have run the br8eg with no problems , a slighty hotter plug! in the end you may have to jet slightly!!
Just remember it is a race bike and wasn't designed to lightly trail ride she likes to be wfo !!
Im one to change the trans oil every ride but that would a days riding! or a days racing, but to me it's not that the oil is broke down, it's the particles in the oil. fine metal,aluminium and clutch fiber will kill the life of trans bearings imo. I run a mag drainplug and it's a little fuzzy every change since the bike was new!
Thanks for al the good info.. what's everyone have there needle set at? Also I'm running br8eg plugs would I do better going to a 9?
  • Similar Content
    • By D.Barrett
      Kicking around the idea of selling my CR250. I have other bikes and never get a chance to ride this one.
      This is a well-maintained bike with tons of aftermarket parts. It's set up primarily for woods/single-track riding, but will still do just fine on an MX track.
      Engine:
      -Fresh Pro-X top end(<1 hour)
      -FMF Gnarly pipe & FMF Shorty silencer(<1 hour on fresh packing)
      -PWK Air-Striker Carburetor(bought new from JD Jetting last year)
      -Steahy 10oz. Flywheel Weight
      -Boyesen Rad Valve with Carbon-fiber reeds
      -TwinAir air filter
      Misc:
      -Excel Pro-Series Wheels(19"/21")
      -Brand-new Shinko tires(546 Front, 505 Cheater Rear not mounted yet) w/ Heavy-duty tubes
      -Works Connection Radiator Guards
      -Skid Plate
      -FMF Factory 909 Handlebars
      -Polished Frame
      -Sunstar 13/51 Steel Sprockets(new in box)
      I'm sure I'm missing a few odds and ends. Comes with a Bill of Sale only. (708)287-1998 - Dave
    • By waldo
      Parting out 2000 cr 250r: frame 150.00, seat with brand new fx cover 30.00, sub frame 30.00, pro circuit works pipe 50.00, kick starter 10 bucks, tank with shrouds 30.00, rear shock 45.00, swing arm 40.00.  make offer on all other parts in picture. Buyer pays shipping from 36092 zip.
    • By BabyGroot69
      Hello,
      I could not seem to find a similar thread so if one exists I apologize. I have an 02 cr250r with an 01 motor. I need to buy a new silencer with a spark arrestor because the current one does not have one. I am not sure if the owner before me used an 01 or 02 silencer because I have read the frame had significant changes from 01 to 02. Any thoughts? Thanks!
    • By Christo6060
      I want to restore a 1996 cr80 that doesn’t have any graphics and absolutely love the 1994 cr125r tank shroud graphics, I can’t seem to find anything that fits the cr80 with those graphics. I found one last week but lost the page and couldn’t track it down again, do the cr125r graphics fit the cr80 tank shrouds? or does anyone know where someone could make them for cheap or know about any in Australia
    • By cerialsledder
      Hey guys,
      Could someone please explain the numbers on a needle jet for a mikuni carb?  I'm currently running a 38-73 needle but a lot of the people I talk to say I would be happier running a 38-70 needle.  I don't have a problem with going with what other recommend but I would like to understand the numbering for the needles first.  I understand the nozzle sizes, main jet and pilot jet it's just this damn needle thingamobob
      Thanks a lot
