32mm Mikuni Flatslide on XR250 tuning help
Just installed this carb. Today was the first ride.
The bike :
2001 Honda XR250
Opened airbox, header welds ground, UNI airfilter, FMF exhaust, stock cam and bore.
Halifax Va., 494 elevation
Symptoms :
Bike cranks well, idles well, when slowly using first 1/8th of throttle it stumbles and does not idle well, sometimes almost dies out(on flat pavement mind you). Improves when warmed up more. Bike runs kind of flat 1/4 of throttle and accelerates well in the upper portion of the throttle. Runs better when accelerated more quickly. Tried a bit of slow tight woods maneuvering from sitting still to try and tractor. The bike would cut out. Had to turn idle up and use throttle and clucth more than usual.
Thoughts :
I was thinking it was perhaps rich. Over carbeurated. No real experience doing tuning but have done some research. Called XRsonly that I got bike from. Tuner said it came set for elevation of 3200 feet. Paper sent with carb gave the following informaiton.
Carb settings :
195 Main Jet, 35 Pilot Jet, 2.0 air jet, a 6DH3 Needle(clip in middle position) and 0-2 neelde jet (nozzle)
Carb came with aditional jets higher and lower.
Here is a pic of the plug. I pulled it after doing some riding at the upper rpms then taken down to low rpms.
ry%3D480
Before getting into the carb the only thing I have tried to adjust is the air/fuel screw which seems to run best at its initial setting of 2 1/4 turns out. Idling and cranking becomes difficult if turned in or out.
My question is since it seems to be running rich should I first change out the pilots or the clip on the needle? Harescramble on Sunday so hoping to get this worked out. Any help would be much appreciated. :thumbsup:
  • Similar Content
    • By SNORE125
      Anyone else have 130 main and 38 pilot jets already in the carb I took the wifes ttr 230 carb apart to add the bigger jets and this bike from 05 that I bought new already had them in it? I was reading that they came with a 125 main and a 36 pilot.
    • By Charles Joseph Miron
      Hello all.  Need a helping hand here..
      I bought an older TT225 and am not about to spend almost $600 on a new carburetor for it. So I'm hoping someone can help me out with an idea of what (other than original carburetor) style, type and brand I should go with..  I'm also having a bit of trouble finding info on this bike.  It's a 1986 Yamaha TT225.
      Thank you in advanced
      Charles
    • By Br0ck
      Hey guys, I went on vacation all summer and let my bike sit (2002 CR250). When I got back I ripped it apart and cleaned carburetor and put it back together and it started fine and ran alright, but idled really high. I adjusted the idle screw and realized it was a ridiculous amount of turns out. I can't remember exactly how many but id say 6+ turns out. My killswitch was a POS and didn't work anymore so I replaced it with an oem replacement. My last ride I crashed the bike pretty bad and I was off the bike for 2 weeks. I can't get the bike to start ever since I got installed the new killswitch. I think I wired it right I just replaced one wire at a time and it looked pretty straight forward. I verified it by testing spark while holding it in I was getting no spark but with it in running position it would spark.
      Anyway I am just looking for some base settings for the Mikuni TMX to get my bike running again, my carburetor has a 35 Pilot and 380 Main jet which appear to be stock. I am located in Edmonton, AB, Canada which is about 2500ft and usually ride between 10-25 celcius.
      Thanks for any replies.
    • By Goon Rides
      Hey guys... so I have a problem... I took the bike at Cal City, broke it in, and while I was doing so, the bike was bogging in first gear (Yes, first gear). Also it doesn't idle at all. I have to keep blipping it otherwise it'll stall. So I adjusted the screw circled in image 1. Well I was listening to the sound of the of the bike, yet the rpm's weren't increasing, and it was still stalling. So then, I unscrewed the screw in image 2, well I found out that it was fully twisted to the right. So then, I twisted it to the left, still nothing; it was still stalling... where's the idle screw? I am sure that the screw in image 1 is for the air/fuel mixture screw, and the screw in image 2 is the idle screw, just broken? I don't know, any and every help would be appreciated.
    • By Zach7018
      So Ive decided its time to pull apart my favorite machine and freshen it up, and I'm looking to make some improvements in the process. I already have a 3x3 mod and a JD jet kit done and it seemed to have changed the world. The stock bike just plain sucked and now its a lot better. I never expect 450 race bike power here but I know there is a little more and I'm wondering if the juice is worth the squeeze. I already plan to add a header and exhaust, an FCR39 carb and stage 1 hotcams. After some research it really seems like those places are where the gains actually come from, so would it be worth it to throw a 434 big bore kit at this bike or just stick with what I already mentioned and a new stock bore top end??? Also my rides are often solo and pretty isolated,how much of a reliability headache can I expect with these mods?
