Questions about KTM SX-F 250 WP forks
Hi,
I am goin to do my first oil change in my 2009 SX-F 250 forks. This is my very first time with WP stuff.
I was thinking while I am in there, is there something to do to make them better? I hear WP fork have a problem with mid-valve. Is there there anything to do?
Also, what oil level would you recommend in outer chambers?
I weight about 190-195 pounds so I am in a heavy side for stock springs, I think.
Any recommendations are welcome.
you need to lower the amount of float to something like 0.3mm then adjust the base to the stiffness to suit you and your riding type, i usually run 340cc in the wp once the mid is sorted.
