Yamaha HELP, Removing lower steering column bolt.
I am having trouble getting my bottom steering column bolt off. Have no handle bars on cause the top of the steering column is smashed/bench towards the tank. I tried a few diff torque wrenches and such but have had no luck. ANY SUGGESTIONS? On a 2007 Raptor 700.
Why would one use a torque wrench to REMOVE a bolt? You took the locking pin off, right? Probably just frozen from rust or sand or someting. Give it a good squirt with WD-40 and let it sit a while, then try again with a large long handled wrench.
