Almost Done
I am having a mechanic install new Kibble White valves and springs in my 06 valve head. I have already installed New timing chain, tensioner and guide.
Anything else that I should think about before I reassemble.
Also any info on how tight the cam chain should be.
Might as well replace the piston and rings while you got it apart.
Absolutely. Piston for sure.
What kind of chain tensioner are you going to use? OEM or a manual?
I have bought OEM and installed them already. can you possibly guide me to a good post on a manual tensioner, that states pros and cons.
