Yet one more carb question
Hi All,
I got a 2006 KLX125 for my daughter a while back, I am having a real time with getting it to run decent. Right now it has the stock carb, pipe and airbox. I have cleaned and recleaned the carb several times, checked valves etc and still no joy. I had a Mikuni VM22 I had bought a while back for my sons bike and never used so I thought I would give it a go.
I bought the adapter from BBR to make it work and it hooked up fine and seemed to idle nice and clean only problem is that it has a bog right off idle if the throttle is snapped open....roll it on slow and no problem. I do have a selection of jets to try both mains and pilots in the following sizes:
pilots:
17.5
30(stock in the VM22)
35
40
45
50
Mains:
95
100(stock in the VM22)
105
If I leave the main at 100 and use a 40 I can get rid of most of the off idle bog but the rpm's hang a bit when you let off. Should I be going the other direction (smaller) or larger than 40. I am at elevation of 4500ft. Any help would be most appreciated ( I have read many posts on the net and really found no solutions) Thanks all.
Brian
Also stock carb is the VM20SS with 102.5 main and 17.5 pilot.
Try the 35 pilot and move the clip on the needle down one notch or two.
The main realy doesn't have any effect on the off idle bog .
BruceD-500,
Thanks for direction, that seemed to work pretty good! Runs so much better than the stock carb now. I have not done a test at WOT to check the plug but since my daughter rarely gets out of third I will not do this right way.
So to sum it up in case anyone else might need the info:
VM22 (from sudco)
BBR adapter for carb
Main 100
Pilot 35
Needle second from bottom
Air/fuel screw 2 1/4 out
4250ft elevation
