Eg 295 gasket question
Which gaskets do you use for the top of the cylinder? re you supposed to use the rubber rings? There is no space for them.
Anyone know.
Working on the rebuild right now
The metal gasket goes in place of the stock o rings for the head. Standard base gasket.
Thanks man I was confused as to whether I was supposed to use both.
That metal gasket is a huge upgrade. No idea if it works better, but its way easier than dealing with the horrible o rings!
