wall thickness of '02 cr 250 frame
Does anyone know where I could find the specifications of the aluminum used on the frame of a 2002 cr250? In particular, I need to know how thick the walls of the main spars are (i.e. .120" or .095" or ?) I'm considering buying one, but it has a couple grooves that appear very deep in the main spars of the frame and I'd like to see how close they are to going all the way through. I know this can be repaired, but I'd like to know what I'm getting into before I seal the deal.
If these grooves are from the Radiator shrouds you mite wanna take a close look at the Radiators mine has a groove on the right side and it was caused by a tweaked Radiator pulling the shroud to the frame just a lil heads up:thumbsup:
P.S. Mines an 03 just bought it last weekend.
The grooves are from the radiator shrouds and are on both sides running all the way across both spars horizontally. If I had to guess, I would say the grooves are ~3/32 deep. Radiators look straight and the bike is in overall good condition (except for the stock pipe which is dented enough to justify replacement.)
If I understand it correctly, individual pieces of the frame are different thicknesses, but each individual piece remains constant in wall thickness (with the exception of where bends were made thereby stretching and thinning the material.) If this is true, I should be able to measure thickness at the drain hole on the bottom/insides of the spars as a reference. If I subtract the depth of the groove from that number it should tell me (within a few thousandths) how much material is left before it rubs all the way through. Does this sound logical?
I think you're on the right track. Many of us have shroud rub in this area. One rider here had the rub go completely through, no catastrophic failure though so that may make you feel a little better. I cant recall if he was able to post a measurement, can't seem to find the thread. I bought a spare auction frame just in case.
I use a piece of fuel line with a slit along it and run that over the edge of the shroud where it rubs (think door edge molding). This was it is softer that the radiator shroud plastic and causes less wear. It does fall off sometime so you may need to glue it in place
I have some frame rub,previous owner didnt care.I made some frame protectors out of thick rubber and zip tied it to the frame,nothing is rubbing through that rubber and its not noticiable.
well I bought it, so either way, it's my problem now! My 450 had similar rubbing issues where my desert tank would touch, never cause for concern, but it is a little more comforting knowing that it hasn't rubbed 95% of the way through.
  • Similar Content
    • By D.Barrett
      Kicking around the idea of selling my CR250. I have other bikes and never get a chance to ride this one.
      This is a well-maintained bike with tons of aftermarket parts. It's set up primarily for woods/single-track riding, but will still do just fine on an MX track.
      Engine:
      -Fresh Pro-X top end(<1 hour)
      -FMF Gnarly pipe & FMF Shorty silencer(<1 hour on fresh packing)
      -PWK Air-Striker Carburetor(bought new from JD Jetting last year)
      -Steahy 10oz. Flywheel Weight
      -Boyesen Rad Valve with Carbon-fiber reeds
      -TwinAir air filter
      Misc:
      -Excel Pro-Series Wheels(19"/21")
      -Brand-new Shinko tires(546 Front, 505 Cheater Rear not mounted yet) w/ Heavy-duty tubes
      -Works Connection Radiator Guards
      -Skid Plate
      -FMF Factory 909 Handlebars
      -Polished Frame
      -Sunstar 13/51 Steel Sprockets(new in box)
      I'm sure I'm missing a few odds and ends. Comes with a Bill of Sale only. (708)287-1998 - Dave
    • By waldo
      Parting out 2000 cr 250r: frame 150.00, seat with brand new fx cover 30.00, sub frame 30.00, pro circuit works pipe 50.00, kick starter 10 bucks, tank with shrouds 30.00, rear shock 45.00, swing arm 40.00.  make offer on all other parts in picture. Buyer pays shipping from 36092 zip.
    • By BabyGroot69
      Hello,
      I could not seem to find a similar thread so if one exists I apologize. I have an 02 cr250r with an 01 motor. I need to buy a new silencer with a spark arrestor because the current one does not have one. I am not sure if the owner before me used an 01 or 02 silencer because I have read the frame had significant changes from 01 to 02. Any thoughts? Thanks!
    • By Christo6060
      I want to restore a 1996 cr80 that doesn’t have any graphics and absolutely love the 1994 cr125r tank shroud graphics, I can’t seem to find anything that fits the cr80 with those graphics. I found one last week but lost the page and couldn’t track it down again, do the cr125r graphics fit the cr80 tank shrouds? or does anyone know where someone could make them for cheap or know about any in Australia
    • By cerialsledder
      Hey guys,
      Could someone please explain the numbers on a needle jet for a mikuni carb?  I'm currently running a 38-73 needle but a lot of the people I talk to say I would be happier running a 38-70 needle.  I don't have a problem with going with what other recommend but I would like to understand the numbering for the needles first.  I understand the nozzle sizes, main jet and pilot jet it's just this damn needle thingamobob
      Thanks a lot
