cr-80 seized up. need help please!
so i was riding top gear along highway home from trails and i went to slow down and let the engine brake for me but when i went down a few gears the throttle wouldnt respond and my bike( honda cr 80 2002) seized up and wouldnt start again, the kickstart wont budge and it wont clutch start either the back wheel just locks, so i checked the oil and stupid me hadnt changed it in a while and it had a tiny bit but honestly its was prety much empty:bonk::thumbsup:
i dont know too much about bikes and was hoping somebodycould pleaseexplain to me how to fix it and how much it will probably cost and anything else
cheers
well, it sounds like you are going to be tearing down your engine soon. on a 2 stroke the oil in the motor is only for the gearbox, it has nothing to do with the piston or the crank(that is why you mix the gas with oil). anyway, when the engine on a 2 stroke is spinning faster than idle and you are not giving it gas it is possible to seize the engine. so you will most likely have to rebuild both the top and bottom end, but it shouldnt be too bad. get yourself a sevice manual and take it one step at a time and stay organized so you know where every single part goes.
You've at least seized the piston to the cylinder. Might have ruined the crank too. Using the engine braking like you did is a classic way to seize a 2-stroke. Tough lesson learned there. Once you get it running again, when you need to slow from top speed, pull in the clutch and use your brakes.
1. wristpin is seized
2. crank bearing is seized
3. rod bearing is seized
4. the sky's the limit
unless you are pretty mechanically inclined, i would sell it to someone who knows how to fix stuff
  • Similar Content
    • By fudgypup
      Garrett Poucher and Skyler Howes of Garrett Offroad Racing are headed to Dakar!  These US privateers are headed there for their first times but Skyler is fresh off a victory at last week's Baja Rally, won the Sonora Rally in March and this team placed third in the Baja 1000.
      They have a fundraising link set up and could use your help.
      I raced with Garrett at Baja Rally last year and then both of them at Sonora and was honored to pit with them as well.  They're both super guys and work their assess off.  I think they both have good chances of not only finishing the 11 days of Dakar but placing well.
      They're doing some rally training events this Sat, Oct 20 in Santa Clarita, CA and then another Oct 28th in St. George Utah so if you've ever considered learning rally raid navigation, this is your chance!  It's a lot of fun too.  More info on that at the link.
    • By Big64N
      Good condition with a long list of high end upgrade parts.
      Rekluse EXP 3.0 with cover and slave
      EVO- Ellensburg suspension tuning for 6' 200# expert rider
      Fork bleeders
      Trail-tech map switch
      Moose 1-1/8 flex bar
      CYCRA probend bar guards
      SXS skid plate with linkage plate
      Clutch and water pump guards
      Frame guards
      Fastway Evolution III pegs
      SRT Pro Armor radiator and rear rotor guards
      Acerbic Front rotor guard
      TM designs chain guides
      DID race chain
      Renthal sprockets
      Gripper seat
      FMF F-bomb header
      Dirt Tricks timing chain tensioner
      Pro Wheel, wheels
      Tubliss front and rear
      New top end and valve adjustment 60 hours old
      Many more aftermarket parts as well as spare parts and service manuals included in the sale.  Willing to include 4 sets of tires with 80% tread left for full price.
      Great bike with plenty of life left and set up for anything from single track woods to wide open dessert.
      Can hang with any of the 450's but is much easier to handle in the tight woods.
      Priced to sell at $6000.00
      Willing to consider reasonable offers but no trades or carry.
    • By filterx
      34 Days and what ever in Beautiful Chile
      http://www.fim-isde.com/home/
    • By Project57
      So if I can’t buy a used bike from out state looking for anyone that has or knows of a low mileage California 2017 / 2018 Beta 500 RRS?
      Thanks in advance!
    • By Project57
      Looking to buy a used Beta 2017 500 RRS from outside California.  Can I plate (Register with CA DMV) the bike in CA?  If so what is the best way?  Don't have the money to put down for a new bike from a Dealer in CA.  Any help or sugguestions would be appreciated.  Thanks in advance.
