XR650L Questions
I have decided on buying a new XR650L. I have a few questions:
- are Dave's Carb Mods the same as uncorking?
- what is the correct jetting for 0-1500 ft?
- I am 6'4" tall and weigh 300 lbs. Will I need to get the shocks replaced to support my weight? If yes, where can I find some?
- according to the Honda website, the MSRP is $6,499; what can I reasonably expect to talk a dealer down to? I have looked around and the lowest I found was around $5,500; is that accurate?
Edited by TaGaDvAnCe
Dave's mods are typically done as part of the "uncorking" procedure.
Plan to: remove the airbox snorkel, replace the paper air filter with a good foam filter, remove the smog octopus (leave the crankcase breather oil separator in place), install block-off plates on the engine where you removed the smog crap (you can easily make these out of aluminum stock), rejet the carb, shim the needle, and drill the slide. Done!
New shock? no' new spring? YES! I would recommend replacing the fork springs as well as the shock spring. A fork bridge would also be a good idea to stiffen up the fork... unless you plan to do a USD swap.
Price on a new bike? Dunno... I wouldn't look at new bikes as there are too many used, low mile XRLs on the market at some very good prices.
I was Googling around just last night looking at new XRL's in our area ( Georgia) and most of the ones I saw seemed to come in around $5600-5800, so I'd say $5500 is pretty decent. I have read some folks reporting new '09's for $4999, but I think that's the exception, I couldn't find anything that low around here.
I would prefer to buy used. It would be nice if I didn't have to do the mods myself. When I search craigslist (via searchtempest.com) there isn't much available in my area [97420]; most of the listed bikes cost >= $4,000. I would just assume pay the extra $1,500 for a new bike. Where else should I search?
Thank you both very much =)
I've seen them go for around $2,500 for 2001 and newer. you just have to be patient if you were to wait for a used one. However a new bike would be great so you could do the breakin yourself and the mods. you would learn a lot doing the work yourself
Speaking of the break-in, should it be broken in before or after it is uncorked? Does it even matter?
You would learn a lot doing the work yourself.
I didn't think of that. It would probably be fun too.
This is the first time in a looooong time that there are no XRLs in the Boise Craigslist. There were a few that were listed off and on for quite a while. If they didn't sell last fall, they will probably pop up again. Craiglist Idaho and Oregon has a BUNCH of used pigs for sale...
There are a couple of 02's in Bend for $2900 & $2950:http://bend.craigslist.org/mcy/2322897075.html http://bend.craigslist.org/mcy/2299215610.html.
A nicely modded '07 in Woodland for $4900: http://portland.craigslist.org/clk/mcy/2346481604.html
A '97 in CdA, Idaho for $2500:http://spokane.craigslist.org/mcy/2328821421.html
  • Similar Content
    • By TheLastByte
      Contemplating picking up a BRP in the near future and looking for some perspective.The current owner claims that the bike has about six hundred hours on it, but there's no way for me to confirm as the odo's not accurate.
      I know brp's have a reputation for running forever on stock top ends, but they must eventually have an expiration date. What should I look for on a high mileage bike like this to make sure I'm not setting myself up for disappointment? Also, What are some non engine/transmission related issues I should look for?
    • By TanSnowman51
      Guys,
      Have been riding my 650L for over a year and a half and have been loving every second! In August I moved back to Reno after finishing up my masters at Arizona State. I have been spending most of my time riding around verdi to stampede and the Dog Valley road area. Always looking for riding buddies.
      Was curious what everyone was doing as far as Daves mods or jet kit for the upper elevations 4,000 to 8,000 feet?
      FMF Q4 exhaust, smog delete done so far!
      Thanks!
    • By Alexandre Askmo
      Hey dear folk!
      I need your help.
      A bit of background info, I’m a complete noob when it comes to holding a wrench and doing anything more than filling up the bike. I have however had an interest for as long as I’ve had a bike to make it mine, and that’s why I’m writing to you now. I just bought a donor bike, a Honda NX650 which a friend of mine is helping me fix up and then modify to my liking (I’m hoping to end up with a gorgeous scrambler in about 9 months).
      We found a hairline scratch in the cylinder and need to bore it. This leads me to my question.
      Should I get a 1st overbore performance piston or keep the compression ratio as is? If so is there anything in particular I will need to modify to tolerate the high compression piston?
      If I do get the performance piston, should I also get a new carburetor, hot cam, and new exhausts? I am planning on new exhausts anyway (2-1 from an XRL) and I’m planning on removing the airbox and getting a K/N pod air filter.
      Again, keep in mind I know nothing, my friend has however fixed up a bunch of XRLs and cars but never really used performance parts. Help me out with the decision please, I would also like to keep the whole build to a reasonable cost (I know this is a very relative number).
      I should also add that I want to keep the DNA of the bike, for example keeping the fuel tank instead of switching to a smaller rounder one as one usually sees in most custom builds. The aim of the whole build is to have an insanely fun bike to ride, both in the city and off-road, as well as giving it a bunch of my personality 😊
      Thanks a lot for any help!
      Best,
      Alex
    • By MrCitizen
      I've been rebuilding/restoring an XR650R for some years now (after toasting the motor in 2013). Sent the motor off to be rebuilt, had a local shop rebuild my forks and shock, and took care of most everything else myself.
      As of a couple months ago I had almost everything assembled and ready to run.
      As a final check before adding fluids to the bike, I decided to stick my boroscope into cylinder and take a look. The results were concerning.
      These boroscope pics looked so gnarly that I pulled the head off the motor to get a more thorough look.
      To say that I'm concerned is an understatement. I have pics of the motor internals pre-rebuild, and can confirm that this is definitely a new piston and replated cylinder. I also have all the old parts from the motor, so it does have a new cam, connecting rod, valves, and basically everything else I expected to have replaced.
      The builder "ran the motor briefly to confirm everything ran alright" and then shipped it back to me. I reached out to him with these pics and he said,
      The piston looks like this because he had it machined from 12:1 to 11:1 compression. The streaks on the cylinder wall are normal for one that isn't broken in yet. Regarding the valve impacts in the piston head: "My concern is that something may have passed through the cylinder. How does it run?" I've never run this motor. I can feel these streaks in the cylinder wall with my fingernail. Did he re-use a piston from some other motor?
      Is this dude jerking my chain or is this motor fine to run?
      He's a fairly well-known builder in the XR community and was recommended to me by guys in the (now-gone) XR650R forum.
    • By Jonas Reppe
      I got my XR600r dirt bike giving me a carb issue that I just can not get worked out. It starts first kick and idles well, throttle cracks off nice and crisp when you whack it, but if you ease into the throttle to just above idle it's a spit and sputter pile of shit! Lol. I can turn the idle speed adjustment up to a fast idle and it starts spitting and studdering just the same. Done a lot of research and it points to the pilot circuit. I put a rebuild kit in it and have taken it apart and cleaned it seriously 12 times now. I'm at the point of looking for a different carb body to try. They're about $100 though. A new keihn carb is $250 on eBay. Any thoughts? That pilot adjust screw doesn't seem to adjust anything until it's fully seated or falling out. It has ran ok in that idle to 1/4 throttle circuit before but it don't now. The last 6 removal/cleanings haven't made any changes, previous ones did improve the throttle snap when you whack it.
      The main needle clip is on the middle groove.
      I checked for air leak with some starting fluid when it was idling and seen no change to the way it ran, indicating no leaks.
      Bike has stock jet sizes, foam filter, stock exhaust. 1,830' elevation here in South Dakota.
      I'm baffled..
