Fuel leak at the carb.
I just found a fuel leak on my 00 E. I Didnt notice the leak before I went for a short ride but when I got back I found it leaking gas. It looked like it was coming from the float bowl gasket. I pulled it all apart and the seal does not look bad. I just wanted t see if anybody else had had this problem and if there anythink else I need to look for while I have it apart. Thanks in advance
Jake
I went back out and gave it all a good shot of carb cleaner. The bowl was spotless. I threw the tank back on and looked again. Turns out it is the accelerator pump. Its coming up thru the shaft tube. So I guess now is the time to install an aftermarket setup. But are they worth it?
Nope, not at all worth. They are 99.999% hype and bling.
Just but a new diapghram and oring for the pump, maybe a new return spring.
That is what I figured. Thanks for the input. :thumbsup:
I'm having this same problem. Well mine seems the same; it looks like it's leaking from the float bowl gasket, but after sitting for a few days after riding is smells like gas and I gas see that it's leaking.
That is where mine ended up being. The gasket was blown out around the accelerator pump fuel passage. I replaced the bowl gasket and the diaphragm and spring while I was in there as well. It was kind of hard to spot. I pulled the carb off and made sure the bowl was full then I worked the throttle ( being sure not to let the fuel squirt into the intake port on the head. I had to watch carefully but I could see it coming out between the bowl and the base of the carb. Hope that helps
Jake
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
