Dyno Conundrum...
Got my 400sm on the dyno this morning (for free) and was a little confused with the results.
My Bike:
2007drz400sm
3x3
K&N filter
TT 39mm FCR-MX
-160 Main Jet
-200 Main Air Jet
-Pilot Air Jet removed
-45 Pilot Jet
-EMN Needle clip 3
-2 turns fuel screw
-O-ring mod
-Timing screw in 1/2 turn
FMF Powerbomb Header
FMF Titanium 4 (open)
Hotcams intake and exhaust
Conti-force supermoto tire (150) @40.0 PSI
Temp 65.0 F.....Humidity 34%.....Elevation 1221ft
EK X-ring Chain
---Any feedback is appreciated as I thought the bike would make more RWHP
***Run_003 was with airbox cover (side panel) Removed***
needs a smaller main jet.
power numbers are relative to that dyno.
how much power does a stock drz make on that dyno?
power isnt that far off with that pipe.
for the main, would a 158 or 155 work better?
The dyno was a dynojet250i, and I have no idea what a stock drz made on that specific dyno..For what its worth they dynoed a yfz450 with a full motoworks system and PC and it made 38 at the wheels...
And for the pipe...im looking into an mrd/ssw shorty.
with that pipe a 155 is likely correct.
cant compare atv's with motorcycles. they have way more weight to turn at the wheel.
you will be 40hp pretty easy with the mrd pipe.
I understand the ATV to motorcycle comparison i.e. the "for what its worth" part haha
Thanks for the info:thumbsup:
Edit: if i were to run the mrd could i leave the 160 MJ in?
Edited by KaiserRolls
add info
