2005 crf150f bog and low end
i removed the carb and cleaned all the lines with carb cleaner and compressed air. main jet and pilot jet along with everything else is clean and clear. but the bike wont run without the idle on. any suggestions
Is this a 'typo'?
Did you mean to put 'choke'?
yea choke my bad
I'm not positive, but I think you've got the choke mixed up. My 150 won't run with the choke on unless I give it some gas. It'll bog down and have that rich sound to it also mine won't reach too high rpm with the choke on. Happend to me once after not riding for a while
It'got to be starving for fuel somehow... check the float and float valve. Maybe the float isn't floating, or sticking down somehow. --L*64
