Valving from Star-Trek
Hi, I just finished one spare shock I have with a strange valving, all in hope to be able to use thicker oil. The wife put a hold on oil orders and was downright scandalized at the price tag on my shock oil. I have tried using a bleed on both sides so i can use thicker oil. See the check plates with 16mm o.d. shim acting like a pivot for the next shim with 16mm i.d. I should be able to try it next weekend.
Comp:
44.15
16.25
44.2 (16mm i.d.)
(3)44.20
(6)44.15
37.15
32.15
(2)42.20
40.26
38.25
36.30
34.30
32.30
30.30
29.30
28.30
27.30
26.30
25.30
24.30
23.30
22.30
21.30
Rebound:
40.2
16.25
40.2 (16mm i.d.)
40.2
28.10
40.30
38.25
36.30
34.30
32.30
30.30
29.30
(2)28.30
27.30
26.30
Very interesting valve stack . I have seen some used like this.
I us Motorex SD1 in the shocks , but what oil are you trying. I would suggest you try some synthetic ATF . It usis a good substitute and is fairly inexpensive.
