rim choice help!
Well it is time for me to head up to the dunes here in like a month and I want to get a complete rim setup for my paddle instead of always having to change the tires of the rim. I was just wondering if I specifically had to buy a rim off of an 06 kx250f or if I can buy one that was off of let's say a Crf 250 or 450. Thanks I need some help
I take it you have an 06 kx250f. If so a 06-11 hub and rim setup will bolt up to your 06. Sprocket and rotors are also the same. Check out ebay you can usually pick them up cheap.
