Pinging
Just picked up a used '07 DRZ400SM bone stock with only 600 miles. Noticed heavy pinging at anything more than half throttle. Suspect lean factory jetting. Is that probably it?
Thanks
'07, 600miles, bonestock, nice find.
Sounds like your 1st mod should be the 3x3, jd kit (JDS005 IIRC) and imo, kientech extended fuel screw.
fixed up mine, it runs way better.
What's the fuel quality like where you live?..Try putting higher octane fuel in and see if it stops the pinging....
Ensure you are not laboring the engine...let it rev out freely....i.e....like don't have it in 5th , trying to accelerate from 30km/h..
I would install a JD jet kit and do 3x3...
Also have a look thru the FAQ section , locktite fixes etc...http://www.thumpertalk.com/forum/forumdisplay.php?f=397
Thanks! I'm pretty excited about this, its my second DRZSM, the first, a black 05 came fully modded including Hotcams. Sold it a year ago, missed it, found this bone stock one in blue/white. Gas is good up here, no alcohol, but I'll switch to high octane until rejetted. I'm not lugging but it pings only at higher revs only when the throttle is cracked open, goes super lean. Still not fully broken in so I'm careful about lugging and staying off the highway. I read up the FAQ, just two more quick questions. At what mileage can I switch to full synth oil? What is the quietest full exhaust system? Is there such a thing? Last one had Yosh, pretty loud.
FMF Q4 with megabomb is probably the quietest aftermarket setup. But you won't gain much over the stock if anything. Save your money and stay with the stock setup if you want to keep the noise down.
Mike :thumbsup::confused:
Go to full syn anytime now.....
What m22 said , but.......
You will need have a free flowing pipe and make some more noise to get better performance from a DRZ..
SSW/MRD or Yoshimura Ti has been tested to be the best...
As you said, it might have had a partially restricted mj from sitting. i drained the 87 fuel, refilled with Chevron 94 and 100ml of Seafoam... After five minutes it was running perfectly, no more pinging at all. I'll switch back to 87 next tank to see if its cured. Meanwhile I'll order a jet kit. Will probably stay with stock exhaust for now, stealth is good around here on the backroads. Too much bad press and fuming neighbors with loud sportbikes and cruisers causing problems. With a JD or Dynojet kit and stock exhaust, do I need a K&N or is the stock air filter ok? Thanks.
stock filter and pipe work fine, with my jdkit.
yep, quiet is good with current rcmp press release.
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
