YZ465 stator swap?
does anyone know if i can take an it465 stator and put it in my yz465 motor to hook up a headlight?
No but you can put the WR426 stator and flywheel in there and get about 100 watts.
Really?
Yes, there is a mod that you have to do to the stator to make it work with the YZ CDI box.
Don't sound right to me, the YZ/IT is an old air cooled 2 stroke, the 426 is a modern 4 stroke.
I've never done this swap but it sounds highly unlikely these components would interchange.
ya i wouldnt risk it but considering that the it and yz 465 are the same except for the lighting coil and different magneto, it should work
My bad guys, I read the post wrong. I thought it said YZ426. Disregard what i said.
might not need the the complete stator assembly I am pretty darn sure that the stator plates are the same between yz 465/490 and the it 465/490 and the only difference would be a seperate lighting coil that was not bolted on the yz
