speed wobbles on braking/accelerating bumps
i have a 06 yz125 and theres a straight section on the track with braking/ accelerating bumps and ill be 4th gear flaying on theme and start getting speed wobbles, and one time so bad almost crashed because of it, hard to, i do have my suspension set up for my weight, any thought on what it could, compresion/rebound issue?
how much fork through the triple clamps are you running? also the rear sag numbers ?
well i know the sag is set correctly, it was set by the people at the suspension place, you mean how far is the sag? 2 and a half 3 inches maybe, and the forks are right on the line that goes around theme, if you know what im talking about, but the line means i think they should not be moved down any frther
you need 103mm or just over 4 inches , also to make it more stable you can pull the forks downwards 3 mm more in the clamps , this will make it much more stable
could it also be body positioning, i think when i put my weight towards the rear more it helps, and i think there far as they can go, there on the line that is in the forks,
As already stated look at your rear sag!
You may need some help to measure it properly, get on the bike and assume your normal riding position and try to get 100mm -4" of sag if this is ok drop the forks through the clamps till flush with the tops this will help loads
That doesn't mean your sag is set correctly. Check the numbers for yourself. Makes a huge difference.
  • Similar Content
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By hondahondo
      A few picks of my winter project.
    • By Luke Hufford
      Hey guys. I recently purchased a 16 yz250x and the first 2 rides i LOVED the suspension. Then the day before a race i reset all my clickers to stock and everything felt like crap. No plushness at all and deflected off everything. I now have a 5.4 shock spring for my 190 pound weight and dialed in sag. Any recommendations on where i should go from here? Right now the fork is 12 out on comp and 15 out on rebound. Shock is 1.75 turns out on hsc, 14 out on lsc, and 18 out on rebound. Any help would be appreciated!
    • By jake gu
      Today we’re going to be talking a little bit about automotive suspensions and how they work to smoothen the ride of your car. There are mainly three purposes of the automotive suspension system. First, they support the  weight of the vehicle. Second, they maintain accurate tire contact with the ground. And third, they absorb any shock that you get through the road when you hit a bump.
      Most modern vehicles come with an independent front suspension. Which means if one wheel hits a bump it does not disturb the other wheel. Nowadays, people use Coil Spring to support the majority of weight in the car. As it has a really good characteristics for absorbing any bumps as you go up and down on the road.
      However Springs aren’t very good at dissipating that energy. In fact that’s why you have the shock absorber. Which is there to smoothen out the ride and make sure the tire maintains contact with the road.
      In modern passenger vehicles the two most popular suspensions are McPherson strut and double wishbone style of suspension. The main advantage of the McPherson strut suspension is that it’s really cheap and simple that’s why a lot of manufacturers are moving towards this design. The double wishbone design allows the wheel to stay perpendicular to the body as it navigates a corner or as it goes over a bump. And that maintains good tire contact patch no matter where the wheel is situated. Another advantage of this design is that it can be made adjustable where you can control the position of upper control arms ball Joints.
      Click to Know More About Ball Joints and other Suspension Components
