any chance it's ok - overheated & kept running
looking for some expert opinions before i start tearing into my bike.
i did my 1st hare scramble today.
overtemp light came on early in the race due to pileup in the rocks.
i pulled over a couple of times to let it cool. one time briefly, and another long enought for the light to come off - which came on soon again after getting back on it & continuing.
decided i wasn't quitting & ran the whole race with the overtemp light on.
did a quick ride in the yard after the race & bike seems like it has a new off idle weekspot.
coolant was down a bit, but not too bad. topped up before test ride.
i need to wash the bike & pull the valve cover to start.
any opinions on what i'm gonna need at a minimum.
prob need new rings. hoping my recently rebuilt by eddie bottom end isnt toast.
thanks
yeah it was. coolant level was down a bit after the race.
there was also a distinct knock when running it harder on open uphills.
just wondering if i need to tear this thing all the way down.
thanks eddie
i guess the knock was probably piston slap due to an over-heated, over-expanded cylinder?
what would you do? pull cylinder, measure & inspect top end and replace as needed was going to be my plan. and check side play of con rod.
prob gonna need a new 94mm kit
why did it overheat REHH I mean in the slow stuff I can see but after that ??
did you fit a fan to it ?
I'm assuming the we're talking about the E in your Signature
it's my S model. all my fault, as i took the fan off years ago & sold it...
still run the thermostat too.
rarely have over-heating problems where i normally ride. didn't think about the possibility of over-heating yesterday until the light came on - yep...too late.
the course was constantly changing - it would open up for a little bit, then back to tight stuff.
oh well...at least i had fun
i'm going to look for a used fan, a higher pressure rad cap & make sure my rads are clean(not obstructed with dirt).
i removed the cylinder today and everything looks good by eye.
haven't measured anything yet, but nothing obvious.
eddie - can you get rings & circlips for the 94 mm JE piston?
if the rings are not removed from the piston, is it still not a good idea to re-use them?
ok...i'm second guessing my initial findings...again
there is light scoring on the cylinder walls on the front & rear.
there's also possibly some wear on the piston skirt.
i think the cylinder is ok. i'm just not sure if it needs a hone or just some scotch brite.
there's a taper on the piston skirt diameter. it measures approx. 2.799" @ the bottom of the skirt and approx. 2.793" @ approx. 1 1/8" up the skirt.
manual says to measure piston skirt .06" from end of skirt.
i tried to show some pics of that
here's the pictures. my appologies for the poor quality.
cylinder
piston
