Big bore, cams, and fcr... what else ?
I just ordered the
JE 434 big bore kit
39mm fcr kit from TT
stage 1 intake and exhaust cams
mcct
I'm going to put this on a 2009 S model along with a MRD I already have.
I live at 800 feet above Sea level.
Should I do the E gasket swap when I do the rest of this ?
Is there anything I'm forgetting ?
Thanks in advance, I truly appreciate it.
Yes I would split the base gasket when you do the swap , it will compliment what you are doing . The only reason not to would be a supply of higher octane gas . If all you can get is the lower octane then it could ping a bit , greg
