Suspension Leaking
Hey all,
I was hoping some one could explain to me how suspension leaks can be fixed diy. My front forks and rear spring are leaking oil pretty bad. Any info would be much appreciated.
Thanks!
Your best bet is to send it to Enzo Racing and have the seals replaced and serviced. By the time you gather up the tools and equipment you are behind the curve.
Joe
Best youtube video out there step by step...
Have fun...
Joe
Enzo does good work, but...you're kidding right? For a leak?
Behind the curve? You can get that wrench and seal bullet and everything you need from Rocky Mountain for less than a 100 bucks. And if you end up with another issue down the road, you're about 45 minutes from having it fixed.
Dunno man...suspension isnt rocket science. Last time I revalved my shock it only took me an hour and that included going to buy the shims I wanted.
