Bike "Jumping" Issue
When i try to start my 02' cr250r in 1st gear with the clutch pulled in it jumps.
Shifts great and rides smooth, just jumps when starting in 1st
Suggestions?
also would it be bad if i didnt get it fixed?
sounds like you have what is called " lurching" your basket is probably grooved as well as your hub. check everything from your cable tension to your basket and plates
what color is the gear oil ? ..
Does it do this when the bike is warmed up or cold? If it happens while cold, it is normal, because clutch plates can be stuck together until the engine warms up. If it is happening while the engine is already warm, then I would definitely inspect the clutch.
