96 JDM XR250 with Keihin VE88 carb woes. Help Please
Hi all
I've been struggling to get my bike running after completely cleaning up the the carby.
The fuel screw adjustment is really driving me up a wall :worthy:
Bike refused to start earlier without full choke but managed to sort that out.
Now she starts up after a bit of a struggle but cuts out when you throttle down...
throttle up is fine... But starting it up is very tough.
Everything except for the fuel screw is checked and sorted. No air leaks etc.
I don't have the proper tool to adjust the fuel screw while the carb is attached cos this model comes with the electric leg and the motor sits right under the carb.
I tried the 2 turns our from a roughly seated fuel screw...no joy
tried about 4 turns out...no joy again...
Does anybody know the stock setting for this carby?
Bike ran perfectly fine with the stock setting all these years until i removed the damn fuel screw for cleaning :confused:
I've ordered the motion pro tool but it will take time to get here...I have a 6 day ride coming up and gotta get the bike running properly :busted:
appreciate any help :thumbsup:
When you reinstalled the fuel screw, were the o-ring and washer positioned properly?
thanks for the reply creeky!
Yes the fuel screw was installed properly. I have the manual in jap and followed the diagrams
removed the carby again last night :thumbsup:
adjusted the fuel screw 2.5 turns out from slightly seated position and now she fires up after a few tries. Rode it and she runs ok without any noticeable issues.
feel the power is a tad bit less though...and when gassing there seems to be a bit of a lag...
Bikes fires up without choke and any effort when engine is warm
cold start is a bit of a hassle.
you think the carby is still running lean?
hope that bloody motion pro adjuster thing gets to me soon :confused:
  • Similar Content
    • By 661Bran28den661
      What’s up guys. Totally new here picked up an XR400R I live in the desert so I’m riding often and enjoy it. But I am having some issues with my  01 XR400R. I brought it out this morning for a putt and it seems to be choking up in the top of second. Like a bog an go bog an go. First seemed fine and third I didn’t make it high enough into the rpms to see. Before I brought it back to the garage. Yesterday I also changed the air filter back to an uni. I had seen the other one had a hole in it and the box was dirty gunned up and oily. I removed the airbox gave it a good clean out wiped everything down very well put a piece of screen over the snorkel Or where it used to be I should say. “Lightly oiled the filter.Also the spark arrester an tip for the bike it did not come with I ended up making one with a piece of flat steel and drilling holes. Whilst doing this. I found also a crack in the pipe. It almost sounds as like there’s a vacuuming or whistle? When revving.The first one I had made worked fine I had no issues. This one I am wondering maybe if it’s a cause of a little too much back pressure.So I’m assuming it’s either a Carb or exhaust problem. Or something that could totally be minuscule. Or major issue. Would definitely like some second opinions and any advice would be greatly appreciated. Thanks guys!
      TWISTIN THROTTLES & CRACKN BOTTLES
    • By ddickinson
      My lanky 14 year old boy started showing an interest in riding MX/Off-Road so I sourced the best beginner friendly, yet dirt worthy, bike I could find: an Ol' Honda XR250R (2004). So far I've replaced a few clutch levers and perches with stock parts. That's gotten old and I'm looking to upgrade to an ASV or Torc1 type fold-able clutch/perch brake combo. Went to purchase online today and to my surprise there were no such parts listed for the XRs. I saw plenty of CRF/CRF-X choices and they seem to differ depending on generation. Obviously I can use nearly any perch/clutch combo as long as the two match; but I was wondering if anyone knew which of these levers was closest to stock? Also, will the first gen CRF250X brake lever work on the XR? These may be stupid questions to some; but I'd rather ask a dumb question than drop money on an ASV brake lever I can't use. Thanks for any help.
      #xr250r#hondaxr
    • By TheLastByte
      Im currently in the market for an xr400r, and considering buying one that's had some heavy engine work done. The current owner claims to have bought it from a friend who's an XR enthusiast. The PO installed a big bore kit and high comp piston, as well as a xrs only pumper carb, rsw triple clamp, aftermarket clutch, street lights, and a whole bunch of bling.
      My main concern is the effect the upgrades will have on the engine's longevity. How much quicker will I be going through top ends with the setup on this bike as opposed to a stock setup, and should I be worrying at all about bottom end longevity as well? I wouldn't mind having to eventually redo the top end, but I don't want to deal with a race bike type top end rebuild schedule on an XR.
      Is there anyone here who's running a bike similar to this one who can give some advice?
    • By Ralph303
      I have a 2001 Honda XR400R. It has a whirring/grinding sound in the lower end and a vibration in the top end. I pulled the valve cover and everything looks good. Decompression lever looks to be in order. Anyone know where I should start looking or just rebuild the whole engine. Ballin on a budget, but really love this bike. It looks like it’s new otherwise. Oil was jet black and thin. Thanks in advance!
    • By junglePIG
      Hi, I have an Xr250r with a buckled/ wobbling front wheel, after trying to true the rim i have broken a spoke.
      I am wondering if it is possible to lace any 36 hole aftermarket rim to the oem hub, also will i need to buy an xr250r specific spoke set. also could i take a 36 hole rim from another front wheel and lace that up???? thanks
