YZ 250 rear shock compression adjuster shim stack and spring
does anybody have the stock shim stack in the high/low speed compression adjuster of the rear shock? I am pretty sure it has not changed since 2006, when the 250 yz got the 18mm shaft. i also need the spring rate, and even better the spring measurements.
I just got a yz 250 2008 that belonged to a 220 lbs rider. I suspect they revalved the compression adjuster and changed the small spring with a stiffer one.
thanks
Edited by ugocross
wrong year
Thought it went 18mm in 06?
yes you are right, my mistake, it has not changed since 2006, thanks
the later ones(08 i think) have 2.7mm holes in the comp adjuster piston as well.
fantastic, thanks a lot. I got a hold of the 2006 stock valving specs of a yz250F and a yz450F too and they all have the same compression adjuster shim stack.
Now I need to verify the small spring in the compression adjuster. I measured it: lengh 28.0mm, outer diameter 19.14 mm, wire diameter 3.08mm. could anybody confirm that those are stock measurements? thanks
